Sign-in / Sign-up
Solved
ASRock x58 extreme mobo problems
  • Motherboards
  • ASrock
  • Devices
  • Keyboards
January 30, 2010 4:43:18 AM
I have a ASRock x58 extreme mobo. I have device failing while playing like my keyboard will stop working or mouse. I go to restart my system and then it fails to start. No post. The only thing I can hear is my PS running and the fans turning on. I cant see the the system code either. Its a 2 digit alpha numeric code to show the status of the system. I am running a OEM win 7 copy. If my mobo is failing will I have to rebuy win7? :ouch:  Any help will be much appreciated.
More about : asrock x58 extreme mobo problems
January 30, 2010 5:01:45 PM
Did I forget something that may be vital to some help? =]
m
l
Best solution
February 2, 2010 11:27:20 PM
RMA it ;-]
It will fail shortly, (and take your CPU with it if you're out of luck).
Eventually touch by hand all of the radiators (especially the one to the left of the CPU) when you're playing the game. If you get burned, you know the problem ;-]
a b V Motherboard
February 9, 2010 10:42:09 PM
Best answer selected by r_manic.
m
l
February 11, 2010 4:34:34 PM
Best answer by default. Just because its the only answer doesnt make it the right answer. I had hoped for a small debate to help me. ASRock thinks its the PS...
m
l
