Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > ~$400: Some parts
~$400: Some parts
Forum Systems : New Build ~$400: Some parts
Hi everybody.
I wanted to build(upgrade) a computer.
I have the following already:
Monitor, Mouse&Keyboard, Dvd-Rom.
In short I want to upgrade my Processor to Core2Quad(therefore MoBo, 4 GB+ RAM, Video Card, 1 TB Hard Drive and everything else those parts might need). I want them to be around $300-450.
I did read "Guide to choosing parts" and it was very helpful. I changed my choices little bit based on that article.
So I made a list (these are very good for my requirements):
[if you can find lower prices for these or better parts, please let me know.]
=================Processor:=====================
- Intel Core 2 Quad Processor Q8200 2.33GHz 1333MHz 4MB LGA775 CPU, OEM ($141)
* Mfr Part Number: EU80580PJ0534MN
* Process Type: Intel Core 2 Quad Processor Q8200
* Frequency: 2.33 GHz
* FSB: 1333 MHz
* Cache: 4 MB
* Process: 45 nm
* Socket: LGA 775
* Package: OEM
Link_http://www.smksuperstore.com/products/viewproduct.ashx?ID=41248&ref=e0e6d680801dabf4bd53752dfca8c87f
I heard that Core2Quad processor has very high temperatures while working so it's very
important to choose a correct fan. So which fan should I choose? (look at the link, right
after the processor or advice better one with as low price as possible) .
================Motherboard:====================
I have two choices, which one should I choose?
Choice#1:
MSI P43 Neo-F LGA 775 Intel P43 ATX Intel Motherboard (75$)
* CPU Type: Core 2 Quad / Core 2 Extreme / Core 2 Duo
* FSB: 1600(OC)/1333/1066/800 MHz.
* South Bridge: Intel ICH10
* Number of Memory Slots: 4×240pin
* Memory Standard: DDR2 667/800/1066
* Maximum Memory Supported: 16GB
* PCI Express 2.0 x16: 1
* PCI Express x1: 2
* Model #: P43 Neo-F
Link_http://www.newegg.com/Product/Product.aspx?Item=N82E16813130229
Choise#2:
- MSI P43 Neo3-F LGA 775 Intel P43 ATX Intel Motherboard (84$)
* FSB: 1600(O.C)/1333MHz
* Memory Standard: DDR2 1066(O.C) / 800
* Channel Supported: Dual Channel
* Model #: P43 Neo3-F
Link_http://www.newegg.com/Product/Product.aspx?Item=N82E16813130185
==============Hard drive:=======================
Is this hard drive a good choice?
- HITACHI Deskstar 7K1000.B 0A38016 1TB SATA II 7200 RPM 16MB Buffer Hard Drive Bulk (80$)
Link_http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10009440&prodlist=dealnews
==============Video card:=======================
Which one is better?
Choice#1:
- ASUS EN9500GT/DI/1G GeForce 9500 GT 1GB 128-bit DDR2 PCI Express 2.0 x16 HDCP Ready SLI
Supported Video Card - Native HDMI integrated (65$)
Link_http://www.newegg.com/Product/Product.aspx?Item=N82E16814121323
Choise#2:
- EVGA 01G-P3-N959-TR GeForce 9500 GT 1GB 128-bit GDDR2 PCI Express 2.0 x16 HDCP Ready SLI
Supported Video Card (65$)
Link_http://www.newegg.com/Product/Product.aspx?Item=N82E16814130395
===============RAM:========================
I heard that a RAM has to be compatible with the MoBo, so please advice me a good RAM(s) with a good price. 4GB+ for ~50$ would be great.
And also I'm thinking about the Power Supply. I bought my computer like 4 years ago, and do you think it needs to be upgraded?
And did I forget something? If yes do I have to buy it?
Reply to msn92
Sorry, I forgot to add:
I want it to use it for average gaming, home video/photo editing, watch movies, internet.
I'm planning to use WinXp&WinSeven&LinuxUbuntu.
I want to build it as soon as possible(I would start buying today, if you people advice me to).
Reply to msn92
Just based off of what you've posted, I would change a lot of the parts. But first, repost using this format: http://www.tomshardware.com/forum/ [...] ild-advice
------------------------------ How To Ask For Build Advice
Homebuilt PC Buying Guide
Reply to jbakerlent
[deleted]~
Message edited by mlcloud on 08-08-2009 at 08:17:06 AM
------------------------------ q9550 2.83ghz
4gb OCZ Platinum DDR2-1066 RAM
Powercolor HD 4890
http://i40.tinypic.com/zks3yu.jpg
Reply to mlcloud
There are 1985 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Having Trouble Picking A Motherboard
By jsrudd, 42 minutes ago:
Here's a build that $976. CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($239.99...
Best offers
Top experts
