Tom's Hardware > Forum > Homebuilt Systems > New System Build > Need some input on my very first home-built PC!
Forum Homebuilt Systems : New System Build - Need some input on my very first home-built PC!
Hey everyone, so I'm building my very first PC and I'd really like some help and/or criticism on what's good and what needs to be changed in my setup! I will be using this PC for MMO gaming and general everyday use.
What I'd Be Ordering:
AMD Phenom II X3 720 2.8GHz Socket AM3 95W Triple-Core Black Processor Model HDZ720WFGIBOX
Scythe SCKTN-3000 92mm Sleeve "KATANA3" 3Heat Pipes CPU Cooler - Retail
ASUS M4A78T-E AM3 AMD 790GX HDMI ATX AMD Motherboard
mushkin HP 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model 996659
Western Digital Caviar Black WD5001AALS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
SAMSUNG DVD Burner Black SATA Model SH-S223L LightScribe Support
Microsoft Windows Vista Home Premium SP1 64-bit for System Builders w/ Tech Guarantee
What I Already Own
2 ATI Radeon HD 4850's (to run in Crossfire)
700Watt Rocketfish Power Supply from BestBuy
Antec 900 Case
HP w2007 20" LCD Monitor
So how's it all look? Anything I should change or any compatibility issues I need to address? Anything I missed? I'm new at this whole PC building thing and would really appreciate any input you'll give me. Thanks!
Sponsored Links
I would go for this RAM
OCZ Flex EX 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Enhanced Bandwidth Desktop
http://www.newegg.com/Product/Prod [...] 6820227404
This HDD
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5"
http://www.newegg.com/Product/Prod [...] 6822136319
and this PSU
OCZ ModXStream Pro OCZ700MXSP 700W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC
http://www.newegg.com/Product/Prod [...] 6817341018
------------------------------ How To Ask For Build Advice
Homebuilt PC Buying Guide
Reply to jbakerlent
Alright swapped out the ram in my Newegg shopping cart.
I think I'm going to stick with the 500gb Caviar Black because there's a good member discount on it (unless the 640gb is faster?).
Is my Rocketfish PSU insufficient? If so I'll gladly return it and get that OCZ or something similar.
Reply to NexVirtus
Is the Rocketfish 700watt going to be enough or do I need something better?
Reply to NexVirtus
It's just generally a good idea to go with a high quality psu since its feeding power to all of your components.
A poor quality psu can damage your system, and ocz is quite a reputable brand.
I'd say if you can return the rocketfish one, you definitely should.
Reply to jonsy2k
Alright, I'll go with the OCZ and return the other.
Any other adjustments I should make before pulling the trigger?
Reply to NexVirtus
There are 504 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
