Wireless help
The Wireless LAN on my Toshiba Satellite A135 has a red x on it. I keep getting a cannot connect the wirless LAN. It says check communication device for bridged settings as you may need to disable the bridge or reconfigure. What does this mean?
1 answer Last reply
More about wireless help
  1. did you install the drivers for the WLAN if not here it is:
    http://hub.opensolaris.org/bin/view/Community+Group+laptop/ath
    this might configure some settings if these weren't installed.
Connectivity Wireless Wireless Lan Wireless Networking
