Hi,
First let me preface this by saying I have read the thread:
Tom's HW Watercooling- Info/FAQs/Links/Stickies
I'm still rather lost.
Currently my system will be approximately the following:
Processor: Intel i7 990x
Memory:
Graphics Card: EVGA GeForce GTX 590 Classified Hydro Copper (after I finish the build I'll save up some extra and buy another for quad sli)
Motherboard: Asus Maximux 4 extreme
Case: Corsair Obsidian 800D
Storage: EITHER one SSD or a WD VilociRaptor & 1 TB of other storage
Power: Corsair AX1200 (suggestions?)
I think that covers everything but the cooling.
I plan to OC the CPU and the RAM. The normal air temperature in my room is about 80*F, varying by up to 20 degrees down in the winter and 5 to 10 degrees up in the summer.
In the case there is room for 1 triple 120 radiator, plus plenty of space for other cooling components.
Can someone tell me what Radiator(s), pump, resevoir, CPU block, etc would be good?
I'm quite confused.
Thanks, Brian
Memory:
I'm quite confused.
Thanks, Brian
