Tom's Hardware > Forum > Homebuilt Systems > New System Build > [Solved] Low power, video editing system under $500
Forum Homebuilt Systems : New System Build - [Solved] Low power, video editing system under $500
Best answer from batuchka.
APPROXIMATE PURCHASE DATE: next week
BUDGET RANGE:$500-$600
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Heavy multitasking via web applications, video editing (non-HD, using adobe premier elements, but will upgrade as funds become avail)
PARTS NOT REQUIRED: Keyboard, mouse, monitor, speaker
PREFERRED WEBSITE(S) FOR PARTS: newegg.com
PARTS PREFERENCES: I prefer intel, but also open to AMD
OVERCLOCKING: Most likely
MONITOR RESOLUTION: 1680x1050
ADDITIONAL COMMENTS:
- I want a quite and cool PC. Low power consumption/good power efficiency is necessary, except for the times when I actually do CPU intensive operations (video encoding and stuff).
- I prefer fast RAM and high clock CPU; I don't need quad core.
- On board graphics is okay. Or if I can use my old ATI (AGPx2), that'll do for now. Later I'll upgrade to a descent graphics card.
Thanks bros!!!
Sponsored Links
Thank you for your quick reply.
I have a newbie question.
The MOBO you recommended has a 1GB DDR3 sideport memory which seems to be used for the on board ATI HD 4200.
I don't understand how this triple channel DDR3 thing works, but don't I need 3 same DDR3 memories?
I'll have 2 GB x 2 DDR3 and 1 GB separately if I build the system as you recommended.
Also, how is the overclocking capacity of the MOBO/CPU combination?
Reply to memming
1. It means u can set video ram up to 1GB in BIOS and it will not eat up system RAM. This sideport memory is independent of system RAM
2. Its a dual channel 4 DIMM mobo so run DDR3 memory in pairs and ya same frequency
3. I have personally built on far cheaper AM2+/DDR2 mobos (personally and for clients) with 710 like Biostar TA760G: I can actually OC whilst undervolting @ 1.17V @@ This is designed as an enthusiast mATX even hehe
4. My documented project log running with P2X3 710 including temps, clocks, volts and pics with a far far humbler mobo :P
http://forums.vr-zone.com/troubles [...] tpc-4.html
It runs super cool considering you getting considerable processing power under the hood IMO
Message edited by batuchka on 08-08-2009 at 06:00:32 PM
Reply to batuchka
There are 710 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
