E8400 problem OC
yocheco619
Hi guys, so BF3 demo is out and I planned to OC my E8400 before I upgrade my system. I have run into a problem however. I originally jumped up my CPU frequency to 3.2 by increasing the host frequency. Now however, when I try to jump to 3.4 CPU Frequency (378x9) it does not stay at that level; in the CPU-Z program it shows that it drops to 2.4GHz (when it is 3.0 on standard) and the multiplier drops from 9 to 6. What is going on and how can I keep it going at 3.4? Thanks for any feedback!
4
answers
Last reply
More about e8400 problem
Look in the "Advanced BIOS Options"for the SpeedStep setting. It will be called "EIST" (Enhanced Intel SpeedStep Technology).
I turn off SpeedStep while I am developing my OC settings. Then I turn it back on when I am finished. If you monitor CPU speed with CPU-Z, you can see the speed increase and decrease automatically with a changing CPU load.
For more help on overclocking:
Shadow's Gigabyte motherboard OC guide:
http://www.tomshardware.co.uk/forum/page-245679_11_0.html
It's for an EP35-DS3L but all the Gigabyte Core2 BIOS's are similar.
Go through the guides. Then take your core voltage off Auto and set your memory voltage to factory recommended values. Change the System Memory Multiplier (or from AUTO to 2.00. Then when you increase the FSB, the memory clock will rise in in proportion with it. At an FSB of 333 MHz, your memory clock should be at 667 MHz.
Download CPU-Z to check your FSB:RAM ratio. It should be a 1:1 ratio.
With a good after market cooler (Hiper 212+ or better), you should be able to easily reach 3.6 GHz and many E8400's will reach 4.0 GHz.
Keep you load temps under 70 C and your core voltage under 1.45 volts. -
jsc said:Look in the "Advanced BIOS Options"for the SpeedStep setting. It will be called "EIST" (Enhanced Intel SpeedStep Technology).
Ok So I disabled it but I am still going between 2400 MHz on a 6 Multiplier and 3600 MHz on a 9 multiplier. =/
Related Resources
CPUs
Battlefield
Overclocking
Related Resources
- Q6600 overclock shows in BIOS but not on CPU-Z
- Optimize my overclocking - q6600 ga-ep35-ds3
- E8400 overclocking question
- System Memory Multiplier Help
- My E8400 overclocking project (need your help)
- [CPU] Speed issues and new to O/C, please help
- ASUS P5B Delux/wifi AP lga 775 and OC a E8400
- Memory Multiplier Problems
- Cpu core voltage
- E7500 won't go over 3,5 GHz.
- Looking to OC my E8400, help?
- P5ql-vm epu HELP PLEASE
- Help overclock E2180 to 3.0 on stock voltage
- Question about Wolfdale E8400 overclocking options availability
- Questions about overclocking an E8400 on a P5Q Pro.
