Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > Building my first comptuer. would these parts work well for a gaming PC?
Forum Systems : New Build Building my first comptuer. would these parts work well for a gaming PC?
Processor- http://www.newegg.com/Product/Prod [...] 6819103250
Motherboard- http://www.newegg.com/Product/Prod [...] 6813131323
Video card- http://www.newegg.com/Product/Prod [...] 6814102834
Case- http://www.newegg.com/Product/Prod [...] 6811147112
Power Supply- http://www.newegg.com/Product/Prod [...] 6817182009
RAM- http://www.newegg.com/Product/Prod [...] 6820231136
Hard Drive- http://www.newegg.com/Product/Prod [...] 6822136320
CD Drive-http://www.newegg.com/Product/Product.aspx?Item=N82E16827151188
If you need to know anything else just ask.
Also, if you have any advice for putting it together it would help too. Thanks
Reply to jwhite231
don't get that power supply.....notice the red switch....red switch=bad
go for a phenom II X3 at that price.....
get 2x2G ram.....more expandability
Reply to uh_no
Use the template shown at the top of this board, we can do alot better than that. You are getting an issue prone nvidia board and an ATI card. If you are getting an ATI card you definitely want an AMD chipset. You dont want the rosewill PSU, or the 4x1 kit of ram, a 2x2 kit will treat you better, and that is an older generation phenom, the newer ones are alot better. Edit your post and lets see what we can throw together for you.
Reply to hunter315
This processor will likely out perform the older lower clocked quad, costs the same and provides easier OCing.
http://www.newegg.com/Product/Prod [...] 6819103649
But really we need to know your monitor resolution, uses, and budget.
Reply to hunter315
uses will be gaming and watching videos online mostly.
budget. i dont want to spend a fortune but i also dont want junk
monitor res. right now it is 1024x768 but i am planning on getting a new one
Reply to jwhite231
Okay, i suggest swapping the PSu out for the EA650, it costs the same and provides more power.
http://www.newegg.com/Product/Prod [...] 6817371015
And i just checked out the charts here, the 720 beat the 9750 in the gaming charts and only lost in the synthetic CPU tests so it is definitelty the better value. And modern IGPs can handle 1024x768 rather well so i would suggest holding off on the the discrete card until you get a new monitor, for 1280x1024 you need a 4850/GTS250, for 1680x1050 you need a 4870/GTX260, for 1920x1080/1200 you need a 4890/GTX275 or 2 4850s which ever is less expensive.
Reply to hunter315
ok i understand the switching the psus. what i dont understand is the second paragraph. are you saying i need 2 cards for a higher res monitor?
Reply to jwhite231
No, i listed the ATI card/nVidia card, they are equivilant cards, either one will perform equally well. For a 1920x1200 monitor a single 4890 or a single GTX 275 will run it fine, however 2 4850s in crossfire cost about the same and provide slightly better performance so if you were to get one now and then moved up to one of the really high resolution monitors it provides you a cheaper upgrade than dropping ~200 on a new graphics card, but as your motherboard only has 1 PCI-E 16x slot this isnt an option.
In short, stick with the IGP for now, choose what monitor you want, and then get a suitable graphics card for it.
Reply to hunter315
ok that does make sense. so do you think everything else should work? i know a little about what im doing but not an expert. thanks for bearing with me
Reply to jwhite231
You may have to update the bios for the 720 to work properly depending on what version comes with your board, it is first support with bios version 0511. I definitely recommend the 720 over the 9750, but other than potentially needing to update the bios everything else should work fine.
Reply to hunter315
thanks for the help
Reply to jwhite231
You are quite welcome, any other questions before, during, or after the build please stop by and ask.
Reply to hunter315
There are 1917 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Having Trouble Picking A Motherboard
By jsrudd, 44 minutes ago:
Here's a build that $976. CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($239.99...
Best offers
Top experts
