Tom's Hardware > Forum > CPU & Components > CPUs > I need to upgrade my system PLEASE HELP
Forum CPU & Components : CPUs - I need to upgrade my system PLEASE HELP
I was going to build a new system, but it seems now I can only afford to upgrade!
I have a Velocity Mico (Edge M10).
Motherboard: Abit AN-M2 nView AM2 MF630a mATX
Processor: AMD Athlon 64 X2 6000+ 3.0GHz with Dual Core Tech, Socket AM2
Cooling: AMD Certified High Performance Heatsink/Fan
DDR2 Memory: 2048 Corsair XMS2 DDR2-800 Low Latency Exteme Memory w/ Heat Spreader (2x1024)
PCX Video: 256MB EVGA GeForce 8600 GT (Velocity Micro Performance Edition, 2 x DVI)
I want to be able to play Dragon Age: Origins on the best setting possible at the lowest expense in upgrading this rig.
The Recommended Specs for the game are:
Intel Core 2 Quad 2.4GHz or equivalent
AMD Phenom II X3 Triple Core 2.8GHz
4GB RAM
ATI 3850 512MB or NVIDA 888 GTS 512MB
What is the best option to go from what I have to what I need? How close can I get to the recommended specs without changing the mobo?
Thanks!
Sponsored Links
Your board will run the first generation phenoms, which are available at some places for around $80-100. It will not run phenom II's, as no bios update is available. I would suggest a 4770 video card first for around $109 at newegg, and see how high you can get the settings. You may end up changing the motherboard anyway to use a newer cpu, but the 4770 will transfer over nicely.
Reply to o1die
There are 1113 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
