APPROXIMATE PURCHASE DATE: two weeks later
BUDGET RANGE: 1500~1550 US Dollars
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, Watching Movies, Surfing the web, very little rendering
PARTS NOT REQUIRED: OS, Mouse (Logitech G5)
PREFERRED WEBSITE(S) FOR PARTS: newegg... will order everything from one place (newegg seems to be cheapest anyways)
PARTS PREFERENCES:
I would like to use a monitor of 21.5'' with 1920 x 1080 native resolution.
(was considering http://www.newegg.com/Product/Product.aspx?Item=N82E16824005123)
i7-920 for CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Scythe Mugen 2 CPU cooler: http://www.newegg.com/Product/Product.aspx?Item=N82E16835185093
6 GB of ram, 1600 mhz DDR3 (since I'll be OC'ing the CPU)
Cooler: http://www.newegg.com/Product/Product.aspx?Item=N82E16835185093
Please include these in the budget as well, need them:
http://www.newegg.com/Product/Product.aspx?Item=N82E16899261005
http://www.newegg.com/Product/Product.aspx?Item=N82E16899261002
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
PSU : 750 w or 850 w i guess? 750 w seemed enough though
was considering this HDD, WD Caviar Black 640 gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
Motherboard must be SLI/CF compatible obviously.
Was considering SLI/CF of 260, 275 and 4890 but not sure.
Help with graphics card, keyboard, monitor, case, memory, motherboard, PSU.
Combos welcome...
OVERCLOCKING: Yes
Maybe SLI OR CROSSFIRE: Yes, I want to play at max everything (AA maybe not max, but high AA) for demanding games like crysis.
MONITOR RESOLUTION: 1920 x 1080
ADDITIONAL COMMENTS: I don't care about appearances, and I don't mind noise that much (unless its REALLY bad).
Combo deals are obviously welcome (unless they expire in the next two weeks)
PARTS PREFERENCES:
Combos welcome...
OVERCLOCKING: Yes
