Recommend me a power supply
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Recommend me a power supply
Hi guys,
I've had some trouble with my PC lately and I've figured the problem is with my PSU, so I need a new one. However, I don't really know what I should get, so I came here for your wise advice.
Here are my specs:
CPU : Core2Duo E8500
Mobo: ASUS P5QL-E
GPU : HIS Radeon 4870 (it has two PCI-E power inputs)
My other PSU is a Thermaltake Toughpower 750W, but I figured 750W isn't really necessary for what I have. Actually my main question is what power I really need.
I think my motherboard has one 24-pin connector plus the 8-pin connector.
If you have recommendations from either Thermaltake, Coolermaster, Super Flower or LC Power, that would be great since my local store mainly has PSUs from those manufacturers.
Thanks a lot,
belgerog
Message edited by belgerog on 11-04-2009 at 04:17:01 PM
Sponsored Links
With 500W PSU you have enough for your PC. CoolerMaster, Thermaltake, OCZ....
------------------------------ If you like my answer, select me as the best answer.
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.". Albert Einstein.
Reply to SAINT19
Thermaltake EVO_Blue W0306RU 550W
Reply to obsidian86
Unfortunately, none of those are what I would call really good brands. I prefer Corsair and some Antecs.
I'd recommend a 550 watt Corsair if you could get one.
Message quoted 1 times
Message edited by jsc on 11-05-2009 at 10:08:41 AM
Reply to jsc
The only PSU brand on your list i would recommend is the Coolermaster, a 500W sould be sufficent depending on the number of HDD you have, less than 3 and you'll be fine.
------------------------------ Life is to short to wait for slow technology...
Reply to n@n0
An Antec Earthwatts 500 would be my choice. Mine has been running for almost a year with no problem. Their warranty is also nice.
------------------------------ http://img261.imageshack.us/img261/8605/sigzlu.jpg
AMD Phenom II X4 720 @ 3.0 | Gigabyte MA790GP-UD4H | G.Skill 4GB Pi Black PC6400 | Sapphire HD4850 | WD Caviar Black 1 TB
Reply to xsever
Hi I'm new to system building and currently building the following:
i7 920 (overclocked to 3.8)
6gd ddr corsair ram
2x GTX260
2x 300gd velociraptors
I have a Corsair 850w power supply and want to make sure that this going to be sufficent - on Corsair PSU finder it suggests 1000w - but surely
Reply to nemnems
6gd ddr corsair ram
2x GTX260
Is enough, or see your self. http://www.thermaltake.outervision.com/Power
Reply to SAINT19
This is a good choice PSU for the OP's setup. 500W should be enough for his system, and the EA-500 has two PCI-E power inputs. It is also Antec's top rated power supply on NewEgg. I know OP has stated that he doesn't think his local retailer carries Antec, but it might be nice to check anyway. :sol:
Reply to Antec_Rep
I don't really know about the others but coolermaster makes excellent power supplies. Corsair and Coolermaster are both top contenders. I'd never put one over the others except for the occasonal price difference between them. This subject is completely entitled though so i guess its based on personal expirience. I've just had an excellent expirience with both corsiar and coolermaster.
Reply to blackhawk1928
The general rule of thumb is a high quality 500 to 550 watt power supply with sufficient current (amps) on the 12 volt rail(s) can easily power a system with any single video card made. A high quality 700 to 750 watt power supply with sufficient current (amps) on the 12 volt rail(s) can power a system with two video cards operating in dual mode. There are a few exceptions like the new ATI Radeon HD 5XXX series cards which use less power due to their energy efficiency.
Corsair, PC Power & Cooling, and Seasonic are some of the brands that have a reputation for high quality power supplies that consistently earn high marks in technical reviews. They are reliable, stable, and come with a 5 year warranty. Lately we've been seeing a few other brands offering some high quality units.
Reply to JohnnyLucky
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Recommend me a power supply
There are 503 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
