$600-700 build need some help on parts/critique
MSI 770-C45 AM3 AMD 770 ATX + OCZ ModXStream Pro OCZ500MXSP 500W
Combo Price: $129.98
Patriot Viper 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 $79
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220286
Antec 300 $60 http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
whats a good cheap optical drive? i saw all the samsung were gone and i'd rather not wait. is there another good one or another site?
for hardrive i want 640-750 gb pref 750 as more space is better but 640 can suffice as well
for the videocard i was thinking a 4850
http://www.newegg.com/Product/Product.aspx?Item=N82E16824254035 for monitor Hanns·G Hi-221DPB Black 22" 5ms
is that monitor any good? i havent heard of that brand but its cheap....
Mostly going to be used for 3d modeling, photoshop and gaming. thanks
13 answers Last reply
More about build parts critique
  1. For that resolution monitor a 4850 will give you medium-high on most games but you need a 4870/GTX260 for high on all.
    For a hard drive consider the 640GB caviar black,
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319&Tpk=640%20black%20caviar
    This combo will give you a good motherboard, a great processor, and tons of graphics power to work with
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.216170
    For about the same as a 945, the MSI 770 board, and a 4870.
    Any sata burner that burns the types that you want should do, the differences arent a ton.
  2. "whats a good cheap optical drive? i saw all the samsung were gone and i'd rather not wait. is there another good one or another site? "
    My first choice is Samsung. My very close second choice is LG. For me, it mostly depends on availability. If I am home in the States: Samsung. In Saudi Arabia, no one where I live carries Samsung. I buy LG there.
    lg is fine for a bit better sony are at agood price
    although that combo looks nice i think it would put me over my budget. And I don't think I need all that power as well.
    how does this setup look instead?
    http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=14775848
    are there any good combos for the budget/midrange computer?
  5. It's all pretty good except for the CPU. I would get a 550 minimum or a better yet a 720... You can combo the MOBO with the PSU. Also, it looks like you forgot RAM:
    OCZ Flex EX 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Enhanced Bandwidth Desktop
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820227404
  6. Sony Optiarc 24X DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B - OEM$29.99
    Antec Three Hundred Black Steel ATX Mid Tower Computer Case - Reta $59.95
    Western Digital Caviar Black WD7501AALS 750GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive - OEM$64.99
    Acer X223Wbd Black 22" 5ms Widescreen LCD Monitor - Retai $159.99
    XFX HD-485X-YDFC Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail $109.99
    Arctic Silver 5 Thermal Compound - OEM$6.99
    G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model F3-12800CL9D-4GBNQ - Retail$74.
    AMD Phenom II X3 710 2.6GHz Socket AM3 95W Triple-Core Processor Model HDX710WFGIBOX - Retail $99.00
    OCZ ModXStream Pro OCZ500MXSP 500W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC ... - Retail
    MSI 770-C45 AM3 AMD 770 ATX AMD Motherboard - Retail COMBO $129.98
    $735.87 TOTAL
    How does this look? Monitor good? and actually i think i need a cheap cheap keyboard and mouse
  7. I have a doubt with the monitors you chose acer and hanns g because they aren't that good. I would think Samsung or Asus would be a better choice. Newegg sells some good asus for cheap price.
  8. i see. well i was thinking that one was pretty decent because its a top seller and had a Winner of Customer Choice Award - LCD Monitors thing.
    can you recommend a specifc samsung or asus monitor??
  9. For 3d modeling you really want more than an athlon II 245, its not going to perform nearly as well as a phenom II would, and the quad core would do a lot better.
  10. yeah i figured....i made the switch to an AMD Phenom II X3 710 so it should be pretty good. thanks though
  11. any idea on the monitor though?
  12. This is my favorite monitor: http://accessories.us.dell.com/sna/productdetail.aspx?c=us&cs=19&l=en&s=dhs&sku=320-7339&~tab=specstab. Also try asking the Dell reps for a slight discount. The acer is fine though, this just has higher resolution, and is slightly larger.
    Edit: pasted wrong link
  13. thanks for the suggestion but i hate those type of resolution monitors. sure theyre nice for movies but id rather have a less extremem widescreen for normal viewing stuff
New Build Systems Product
