Help Choosing Ram
If I had to choose between one of these kits, what would you guys recommend?
6GB Kit DDR3 2000 G.Skill-Trident
6GB Kit DDR3 1600 Patriot-Gaming
6G Kit DDR3 1600 Patriot-Signature
6G Kit DDR3 1600 Kingston / G.Skill NQ
All input is appreciated :)
Any other recommendation's on ram kits are also greatly appreciated :)
7 answers Last reply
More about help choosing
    What is your system spec? Is it Core i7 built? If it is then go for 6GB (3x2GB) package.
    Patriot-Gaming 6GB DDR3 1600 would be great but I would go for the chepest in the list.
  2. Yeah its an i7 920 w/ a Asus p6t Deluxe MB
    The prices are as followed, high due to AU pricing.
    6GB Kit DDR3 2000 G.Skill-Trident $225
    * CAS Latency: 9-9-9-24
    * Voltage: 1.65 Volts
    6GB Kit DDR3 1600 Patriot-Gaming $208
    * Memory Timings: 9-9-9-24
    * Voltage Settings: 1.65V
    6G Kit DDR3 1600 Patriot-Signature $175
    6G Kit DDR3 1600 Kingston / G.Skill NQ $175 / $208
    Couldn't find timings or voltage settings for other 3 :(
    Going off a very rudimentary sales site.
    http://www.msy.com.au/Parts/PARTS.pdf
    Any further opinions
  3. Timings and voltage please. You must not choose a memory without knowing the timings and voltage. If you do, you are making an uniformed choice.
  4. Edited above post.
    interesting... what timings are good for DDR3 1333 memory, as i'm buying a new board and cpu... cpu= i3 530
  6. Basically you are looking for a combination of the fastest (lowest) timings and lowest voltage. Timings of 9 are average for 1600mhz memory, 7 for 1333mhz.
    Unless you are planning on overclocking your processor quite a bit, I would opt for the 1333mhz with timings of 7, over 1600mhz memory with timings of 9.
  7. thanks a lot
Memory DDR3 Patriot RAM G.SKILL Product
