SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: gaming, surfing the internet, watching movies (Blu-ray rips , DVD's)
PARTS NOT REQUIRED: Dvd writer
PREFERRED WEBSITE(S) FOR PARTS: I live in india but if you can guide to newegg i get the same price with a max differnce of $10.
PARTS PREFERENCES: I believe AMD is better than Intel but anything is fine with me
OVERCLOCKING: Maybe but right now no no SLI OR CROSSFIRE: Maybe but right now no no
MONITOR RESOLUTION: 1920x1080, 1920x1200
ADDITIONAL COMMENTS: I would like a quiet PC
I've been doing some search on few forums and kind off shortliested few components which fit my budget, i'm not sure if this is the best i can get for the budget but i hope you guys will help me out.
Phenom II X3 720
Biostar TA790GXB/E
Corsair xms2 800MHz 2x2GB
Zebby Bijli (from lynx)->
Corsair VX450 -
ATI HD 4850 ->
Samsung 2233SW or Benq E2200 HD
500GB HDD
If it's silence you're interested in, take hd4770. It uses less energy and is almost as fast as 4850. Remember, you can always oc it and get better results.
Well, he's got a point, I have to admit. Anyway, I prefer hd4770. That fanless 4850 from gigabyte comes with 1gb of ram, which would be another advantage for your resolution.
Thanks for the advise guys.Ok...so its HD4770 then...what about the rest of the components, I mean any suggestions or comments on the stuff that i shortlisted
@sandeep_th the HD 4770s are highly priced because of the scarcity...You can find the HD 4850s cheaper...And @ stock they are little faster than the 4770...
So I would say get the one cheaper...
And anyways that Corsair 450 has more than enough power for the 4850...
And about the HDD - Make sure you get the Seagate 7200.12 drives...
^ It is quiet and cheap but there would be a performance hit...Having just 1 drive might not have a big issue with the noise...
Only when you have multiple drives, the noise becomes a major issue...
So the 7200.12 is a better buy as it will be used as the primary drive...
And one more thing...
One of the major contributor to system noise are the case fans...So replacing them with better quieter ones(Check for low dB and good CFM) would also reduce the noise effectively...
Overall the system is really quite even on load and has been running straight 48 hrs without trouble. Thanks a lot to all of you for helping me.
One last questions, my GPU on load hits high as 80c after playing burnout paradise for 20 minutes. The airflow is fine, im thinking should i replace the stock cooler. I would prefer the temps to be well within 60c.
tell you what, it will be fine on 80c, but of course 60 is much better and if you have cash then go for aftermarket cooler, cards oc abilities will rise as well. forgot to mention, if youre ocing your cpu, check if psu does not get too hot, cause it's only 450wats and might die too fast.
Message edited by szymek on 08-19-2009 at 12:12:33 AM
