I am seeking any advice for my new computer.
My current computer is running a P4 and I've decided to build my own computer. (First time builder)
I am planning on overclocking everything to a safe level.
As far as budget goes I'd like to go by this: Saving money would be ideal but I do not want to sacrifice performance.
I have been reading many articles about i7 builds and I have came up with this.
Motherboard - ASUS P6T SE | $210
I chose the P6T SE because I have had good experiences with ASUS and it is cheaper than the regular P6T (I do not need any of the removed features, unless it will conflict with my overclocking)
Alternative: ASRock x58 Extreme | $180
Processor - i7 920 | $280
I chose the i7 920 because of its price/speed.
Processor Fan - Zalman CNPS 9700 110mm | $ 55
I like Zalman coolers/fans but I am wondering if it is necessary to even have a CPU fan.
I have heard the stock Intel fan is pretty good.
Graphics - 2x Sapphire Radeon HD 4870 1GB | $320
I have heard good things about this card. I am going to be running them in crossfire.
Will it be necessary to buy a cooler if I overclock them?
Memory = Mushkin DDR3 3x2GB 1600 | $180
I have liked the Mushkin company in the past and these sticks had good timings.
[strike]How much overclocking do I have to do to get the 1600 speed?[/strike]
Edit 1: Regarding processor vs ram speed, what do I have to do to get it to perform at 1600 instead of 1066?
Case = LIAN LI PC-60FWB | $150
LIAN LI makes great cases so I chose one which fits my needs from them.
Power Supply = PC Power & Cooling 750W | $120
This one was based off a recommendation from a friend. (Brand name)
It should be able to support my power needs as far as I know.
Hard Drive = Seagate Barracuda 750 GB 7200 RPM 32MB Cache SATA 3.0Gb/s | $80
I have had a better experience with Seagate than Western Digital, which was the other option I was considering.
CD Drive = Sony Optiarc Black | $31
I just picked a cheap one which had the best specs.
Total $1426
I welcome any advice so PLEASE post.
If there are any alternatives with better performance with a similar price, please let me know.
Thank you for your time.
All links are to newegg. I prefer newegg but any other reputable company would be fine.
PS: I also would like a good widescreen monitor.
Total $1426
