Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help With Custom Netbook
Forum Homebuilt Systems : New System Build - Help With Custom Netbook
APPROXIMATE PURCHASE DATE: Within the week
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Internet surfing, Multitasking, Messengers
PARTS NOT REQUIRED: N/A
PREFERRED WEBSITE(S) FOR PARTS: newegg
PARTS PREFERENCES: OCZ Neutrino 10" DIY Netbook
OVERCLOCKING: yes
MONITOR RESOLUTION: whichever would fit best
ADDITIONAL COMMENTS: Would like it to be quiet if it can be, and cheap as possible with everything that is needed for it to be used for.
Sponsored Links
Are you looking for battery life or performance? The former requires an Atom, while the latter involves a low-power Core 2 Duo.
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
There are 1077 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
