How in the hell am I supposed to put the AM3 clip on the cpu socket? The part with the tab keeps falling off when I try to clip it on . Maybe I'm just an idiot?
it can be a little hard but you have to get the clip that is on the higher side of the mobo in first. you may need to use a flathead but BE CAREFUL! then you just take the other side and pull it down into place!
