Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Will my Toughpower 650W power a AMD 5850 build?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Will my Toughpower 650W power a AMD 5850 build?
Hi everyone,
I'm building a new PC, and I'm trying to work out whether my old power supply will power it?
The power supply is a Toughpower 650W W0104RB - here's the technical blurb:
http://www.specialtech.co.uk/spsho [...] at=0&page=
The new build will be:
Gigabyte P55-UD4
Core i7 860
AMD 5850
6gb OCZ ram
1Tb harddrive + DVD
I know nada about power supplies - is this going to work ok?
Matthew.
Sponsored Links
That's more than enough power for your system.
Reply to TheViper
Thanks Viper - I know the watts are good, but just checking I've got the right amount of leads, volts and amps and all of that?
Reply to mistermat
Unless you have 15 240 mm fans you didn't list, you'll have plenty of power connectors.
Reply to TheViper
Nice one, thanks again :)
Reply to mistermat
No problem!
Here are the official power requirements for the brand new ATI Radeon HD 5850 and HD 5870 video cards.
ATI Radeon™ HD5850 System Requirements:
PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard
500 Watt or greater power supply with two 75W 6-pin PCI Express® power connectors recommended
600 Watt and four 6-pin connectors for ATI CrossFireX™ technology in dual mode
ATI Radeon™ HD5870 System Requirements:
600 Watt and four 6-pin connectors for ATI CrossFireX™ technology in • dual mode
The power supply recommendations are for an entire pc system.
Reply to JohnnyLucky
- 0 +
scratch that, i dont know what i was saying haha.
well i definitely think you have enough power
Message edited by ryohei on 11-06-2009 at 04:23:22 AM
Reply to ryohei
There are 879 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 paesan won the Freshman badge
  • 01:00 -pcaddict- won the Freshman badge
  • 01:00 impreza won the Freshman badge
  • 01:00 raulkm won the Uniformed badge
  • 01:00 letus won the Uniformed badge
  • 01:00 pmiddy won the Uniformed badge
  • 01:00 MarcieMark won the Uniformed badge
  • 01:00 kaypeezee won the Uniformed badge
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
