Test cpu fan speed
Forum CPU & Components : Other Components - Test cpu fan speed
how can I run a test on my cpu fan, to make sure it is working correctley?
Sponsored Links
Download HWMonitor from CPU-ID (search on google for link).
Its free and shows you reported fan speeds. If no fan speeds display, there isn't much else you can do. If you're worried about temperatures, HWMonitor will show you those too.
You can download Prime95 and run a torture test if you want to see if it works correctly when the computer is under load.
------------------------------ Intel E8500 - 4.26Ghz - 533 x 8 - on air cooling with DDR2-1066 running native
Sapphire Ati HD4850
Reply to SpidersWeb
Speed Fan is another good free app for watching fans speeds and temps.
Some of these programs take the temperatures from different points so I like to use a mix of apps to get a more thorough assessment.
Reply to TheViper
Tom's Hardware > Forum > CPU & Components > Other Components > Test cpu fan speed
There are 1151 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
