A friend of mine is looking to buy a light portable hard drive of his father can use to store many large photos on while travelling. (I think they're in some raw format, so they take much more space than those out of a typical camera.) I've had a search around and it seems like the Samsung S2 Portable (640GB, USB 2.0) is a good choice... it's apparently light (170 g), small and has a decent storage capacity. But I have no actual experience with this (and know much less about hardware then you all), so I thought I would ask for advice before recommending that he buy it. Oh, if there was anything similar but with a larger storage capacity out there, that would be even better...
Thanks,
Mohan
Thanks,
Mohan
