Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help with building first computer
I am planning on building my first computer...want it to play some high games and need to run things like autocad very smoothly and stuff like that and was thinking of trying to overclock it somewhat but i've never done that either...so here is what i have so far:
Intel Core i7 920 Nehalem 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor ------------------- $279.99
ASUS P6T6 WS Revolution LGA 1366 Intel X58 ATX Intel Motherboard ------------- $349.99
ASUS ENGTX280 OC/HTDI/1G GeForce GTX 280 1GB 512-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card -- $315.00
CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model TR3X6G1600C8 G -------- $139.99
Sony Optiarc Black 24X DVD R 8X DVD RW 12X DVD R DL 24X DVD-R 6X DVD-RW 48X CD-R 32X CD-RW 2MB Cache SATA DVD Burner with LightScribe LightScribe Support - OEM -$30.99
XCLIO Windtunnel Fully Black Finish 1.0 mm SECC Chassis ATX Full Tower Computer Case -- $99.99
Rosewill Xtreme Series RX950-D-B 950W Continuous @40°C ,80 PLUS Certified, ATX12V v2.2 & EPS12V v2.91, SLI Ready CrossFire Ready, Active PFC Power Supply ------------- $129.99
Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM -------------- $89.99
Noctua NH-U12P SE1366 120mm SSO CPU Cooler ---------------------------- $71.99
Creative Sound Blaster X-Fi Titanium Fatal1ty Professional 70SB088600002 7.1 Channels 24-bit 96KHz PCI Express Interface Sound Card -$127.49
ASUS VH242H Black 23.6" 5ms HDMI Full 1080P Widescreen LCD Monitor 300 cd/m2 1000:1 (ASCR 20000:1) Built in Speakers - Retail ----$199.99
i'm not really on a budget or anything but i don't want to go too crazy...if you have any ideas of how i can get better performace with cheaper price tho please tell me
everything on the list had good reviews to the most part but if any of the items are not too good then please tell me also i think all of the items work together, but because this is my first rig i can't tell too much
if you guys can help thank you so much
Sponsored Links
seagate has been troublesome of late so a wd or samsung would work better an rosswell is a bit shifty on a high end system get something like a corsair ocz pc power an cooling for a power supplyy
Message edited by obsidian86 on 08-11-2009 at 10:52:43 PM
Reply to obsidian86
what about this one instead of rosewill: CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply ---$119.99
Reply to max1171
If your going asus I would suggest the Rampage Extreme over that one if your going to spend that much money:
http://www.newegg.com/Product/Prod [...] 6813131352
I would get two 260's and SLI them personally, you will get better performance then one 280
I would go OCZ Platinum 1600:
http://www.newegg.com/Product/Prod [...] 6820227381
I would go with Antec 1200 Full Tower:
http://www.newegg.com/Product/Prod [...] 6811129043
Not a huge fan of Rosewill's power supplies, I like Corsair more (Coirsair 750W)
http://www.newegg.com/Product/Prod [...] 6817139006
The last two Seagate drives we have gotten at work have failed 3 months in, go with WD Black
Sound cards are really not needed now days.
Message edited by jtmoney528 on 08-11-2009 at 10:54:49 PM
Reply to jtmoney528
Also do not forget about checking out combo's :D
Reply to jtmoney528
yeah i've been looking at combos that's why i was gonna get the rosewill
Reply to max1171
that computer sounds really great. but if you really want to push your games to the limit I would reccomend using 2 ATI raedon 4870s.
also you didn't say what OS you were going to get but if I were you I would get a 64 bit version of windows vista.
Reply to Anonymous486
i was actually gonna put windows 7 (64 bit) on it and i would prefer nvidia if i could...i've had a few problems with ati lately
Message edited by max1171 on 08-11-2009 at 11:02:41 PM
Reply to max1171
this is as good as corsair http://www.newegg.com/Product/Prod [...] 6817341011 bit cheaper then the corsair or this corsair combo with the haf 932 http://www.newegg.com/Product/Comb [...] mbo.236865
Message edited by obsidian86 on 08-11-2009 at 11:14:01 PM
Reply to obsidian86
so if i don't need a sound card...what do you do? nothing? lol
Reply to max1171
Most current motherboards come with pretty good onboard sound. I would just try the onboard sound. You can always add a sound card later, but I doubt you'll decide you need it.
Reply to shortstuff_mt
most mother boards come with on board sound cards only time worth getting an extra one is if you running a music studio
Reply to obsidian86
ok yeah i guess i'll just do that...the best thing about building your own is that you can just upgrade everything easily
Reply to max1171
ok so i guess my only question left would be should i spend $200 more and get the i7 950 or stay with the 920?
Reply to max1171
Buying the i7 950 is like lighting fire to $200 since you mentioned you would like to overclock in the future. Both CPU's have about the same overclocking ceiling, so the 950 is a waste of money.
I hope you've been talked out of the Rosewill PSU. The motherboards you're looking at are pretty overpriced, too. I would have a look at these combos.
http://www.newegg.com/Product/Comb [...] mbo.238326 (i7 920 + Asus P6T Deluxe V2)
http://www.newegg.com/Product/Comb [...] 14-130-475 (Evga GTX 275 + 64-bit OS) The GTX 280 you picked is ridiculously overpriced. The GTX 275 offers similar performance for a much more reasonable price.
A lot of people have suggested the Corsair 750TX, but I would step it up to the 850TX if you think you'll ever want to add another GTX 275 in SLI down the road.
CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply - Retail $139.99 - $30 MIR
ok yeah i'll stick with the 920 then i didn't know much about the 950
ok so what i have now...it's getting much better i'm gonna look at shortstuff's links but just so you know what i have on my list now:
Intel Core i7 920 Nehalem 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor ----------------------- $279.99 (deal with board)
ASUS Rampage II Extreme LGA 1366 Intel X58 ATX Intel Motherboard ------------- $359.99 (deal with i7)
ASUS ENGTX260 TOP/HTDI/896M GeForce GTX 260 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card --- $194.99 (x2)
OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3P1600LV6GK --- $124.99
Sony Optiarc Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 48X CD-R 32X CD-RW 2MB Cache SATA DVD Burner with LightScribe LightScribe Support - OEM ------------------------------$30.99
COOLER MASTER HAF 932 RC-932-KKN1-GP Black Steel ATX Full Tower Computer Case - $149.99 (deal with below\/)
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply ---$119.99 (deal with above /\)
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drives ----------------------------- $94.99
ASUS VH242H Black 23.6" 5ms HDMI Full 1080P Widescreen LCD Monitor 300 cd/m2 1000:1 (ASCR 20000:1) Built in Speakers - Retail ---- $199.99
tell me what you think
Message edited by max1171 on 08-12-2009 at 12:03:00 AM
Reply to max1171
ok looking at what shortstuff said...i like the motherboard he lists much better but i think i'd rather go with the two 260s instead of a 275 so do i need the bigger power supply still?
Reply to max1171
Go with that setup
Reply to jtmoney528
You should keep the bigger PSU just to be safe, it might be cutting it a bit close to use 2 GTX260s on a 650 watt PSU especially if you are overclocking in the future. It is always best to have some headroom on your PSU selections.
Reply to hunter315
ok so is asus a good card brand then...better than evga?
Reply to max1171
but i'm getting a 750w it says it above...
Reply to max1171
If those ASUS cards are $195 a piece then they are super overpriced. They cost so much more because they are OC'ed from 576 to 650MHz. For $46 more total you can get 2 GTX275's which will greatly out perform the GTX 260's
http://www.newegg.com/Product/Prod [...] 6814150387
Or you can save $50 and get stocked clocked ones from XFX
http://www.newegg.com/Product/Prod [...] 6814150329
Or for $10 more you can get 2 4890s which will perform on par with the GTX275s
http://www.newegg.com/Product/Prod [...] 6814150359
Really i would suggest just get 1 GTX 275 or 1 4890 for now, if you need a second then get it, but the asus GTX 260s are way more expensive than they should be.
You will notice an XFX trend in my links because they provide a double lifetime warranty(for you and the person you may sell the card to)
Reply to hunter315
I use EVGA for my motherboards and video cards, I just have had great luck with them!
Reply to jtmoney528
yeah that's a lot to think about, but thanks that will help...but like i said before i lean toward nvidia...heard they were better right now
Reply to max1171
It is true that no ATI card can keep up with a GTX295 but ATI provides similar performance for less money in general. Check the benchmarks for the games you want to play, some show a significant preference for nvidia architecture, if the games you want to play do then definitely get a GTX 260 or GTX 275, if not you can save a bit by going with the ATI route.
Reply to hunter315
+1
You certainly can't make the generalization that Nvidia > ATI.
yeah most of the games i play have nvidia splash screens so i'll get the gtx 275 and then just add another one later
Reply to max1171
the 4870x2 is within 15% of it but a 295 is $540 an 4870x2 is 400 but 2 4890s crossfire are near untouchable only 2 gtx 285 can compete an win a few but using 3 or 4 cards the 4890 kills it
Reply to obsidian86
wow ok i don't think i'll be doing any of that for a while...that's just crazy
Reply to max1171
this is like the dragsters of pc's but it gives a good guide as to the level of current tech http://www.ripping.org/benchmarks. [...] c=3DMark06
Reply to obsidian86
what about the cpu cooler? is this one ok no one has talked about it...i was expecting someone to find a better one cuz i just picked one that looked ok
Reply to max1171
Sunbeam core contact freezer performs quite well, it costs $45 before MIR and $25 after
http://www.newegg.com/Product/Prod [...] 6835207004
http://www.newegg.com/Product/Prod [...] 6835207005
Reply to hunter315
the sunbeam core contact is just as good but bit cheaper
Reply to obsidian86
does it fit on i7? i have no idea what fits on what lol
Reply to max1171
If you live close to a MicroCenter the i7 920 is $199.99 in-store pickup only.
http://www.microcenter.com/single_ [...] id=0302727
Reply to VinnyChase
WOW...i wish i did...i might drive out there to save the money i should check to see what else they have cheaper
Reply to max1171
The second link i posted is the mounting bracket for an i7 motherboard, you need to get both. But with that bracket it will fit fine.
Reply to hunter315
so the last thing is should i go for a 950w 850w or 750w?
this is what i have now after all of the above help :D
ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX Intel Motherboard ------------- $289.99(deal with i7)
XFX GX275XAHFF GeForce GTX 275 896MB 448-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card ----- $217.99
Sunbeam CR-CCTF 120 mm Core-Contact Freezer CPU Cooler W/TX-2 ---------------------------- $35.49
Sunbeam CR-LGA1366 LGA 1366 Core I7 Socket Retention Bracket Set --------------------------- $9.99
Message edited by max1171 on 08-12-2009 at 12:53:57 AM
Reply to max1171
Looks good, stick with the corsair 750TX, it will provide you plenty of power for years to come, almost no one needs more than that.
Reply to hunter315
even when i plan on adding another gtx 275 somewhere down the line?
Reply to max1171
Yeah, the 750TX is what is generally suggested for 2 GTX 275s or 2 HD 4890s.
Reply to hunter315
thanks...well i guess that's it unless anyone has some other thoughts
Reply to max1171
There are 1310 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
