Being without a desktop for 2 years (laptop), I've decided to build my own. I have an old PC but I need to build a new one from start and after seeking some advice on EggXpert I just figured I'd post my build at this point, see if I can get even more feedback.
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=16000027
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
ASRock M3A780GXH/128M AM3 AMD 780G HDMI ATX AMD Motherboard
XFX HD-485X-ZDFC Radeon HD 4850 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported
OCZ ModXStream Pro OCZ600MXSP 600W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case
Western Digital Caviar Black WD7501AALS 750GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive - OEM
AMD Phenom II X3 710 2.6GHz Socket AM3 95W Triple-Core Processor
Total: $608 ($633 shipped)
My budget is $600-$650, I will be gaming, I do want crossfire and if I overclock it will be pretty little.
I'm still contemplating going for the Phenom II 720 instead of the 710, so if anyone has any thoughts on that please post. Otherwise I think I'm set to buy this setup but if there are any mediocre parts, incompatibilities, etc. let me know.
I'm hoping to purchase by the end of the week, I figured I'd post now so I could get plenty of feedback here and elsewhere. Thank you!
