Hi there,
It's been a long time since I built my PC, probably 6 years.
I don't have much time to play games these days so I wouldn't want to buy a new machine, but lately I thought about upgrading it a little so it could run WoW smoothly with nice and shiny graphics.
So I went and picked up a Sapphire 3650 HD AGP with 512mb DDR2 and thought "Well, it must at least blow WoW away...".
My system specs right now:
CPU: Intel Pentium 4 3.0GHz
MB: ASUS P4P800 (not deluxe or anything)
RAM: 2x 1GB of Kingston 400MHz DDR CL3
PSU: A 500W max output PSU, not something familiar
OS: Win XP Pro SP3
Old GFX card: ATI Radeon 9800XT (it used to be a beast!
Now back to the subject.
I installed the new 3650 card, turned on the PC, Windows loaded, and the next thing I saw is "Found new hardware", except I had 2 of these... Strangely, my Realtek RTL8139 Ethernet NIC lost its' drivers somehow... I tried to install it again by simply uninstalling and reinstalling it in the device manager and it lost the yellow "!" mark, but it didn't really help because I had no internet or LAN connection even though I got a "Local Area Connection" in the network connections folder.
Meanwhile I got some BSODs with a NDIS.sys and "Driver not equal" kind of errors... but it only happened every 5 minutes so I managed to do some work from one crash to another.
I figured it was just a driver problem and once I install the GFX card's drivers it would solve the network issue.
So I downloaded (from another computer) the latest ATI drivers for the 3600 series (Actually, it was from Sapphire's site). It was the "Hotfix for AGP" version. I installed them and my GFX seemed to be working as expected, although I still had network issues. Somehow by uninstalling and reinstalling the network card itself, aswell as the drivers for it, I got my connection back. Now everytime I reboot my PC I lose the internet connection, even though it's installed correctly in the device manager. So my temporary (and very annoying) solution is to reinstall it in the device manager everytime I reboot.
I then left the network issue alone and wanted to see some action from the new GFX card. I opened up WoW and expected to see high FPS in the login screen, but for some reason I got even less FPS then I had with the 6 year old 9800XT. It wasn't like 2-3 FPS but not something I would expect from this card.
I started to google the web for solutions.
Things I've tried:
- Install older GFX drivers.
- Raise the AGP aperture size from 64 to 256 in the bios (256 was the max, but the card has 512mb ram... does it matter?).
- Checked the core and memory values.
- Remove the network card and see how it runs without it.
- Downloaded new drivers for the network card.
- Connect the power supply of the GFX card straight to the PSU.
- Checked dxdiag > display tab, everything is enabled.
That's it basically, I can't remember what else I tried. I'm pretty sure that the card is connected correctly, also the power supply of it. I don't really know where to continue from here, I don't even know if it's a hardware or software problem.
Please help me with this,
Thanks in advance.
