Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
I'm running short of disk space and can't afford a new laptop hard disk at
present. Is Microsoft's disk compression utility safe? If not, is there a
third party one that is?
"Dave Rado" <drado@onetel.net.uk> wrote in message
news:%234BhjWccEHA.212@TK2MSFTNGP12.phx.gbl...
> Regards
> Dave
If you're using the NTFS filesystem,.
it's extraordinarily safe. Been around a very
long time, all the bugs have likely been worked
out. Have no problems whatsoever with it.
If you're on FAT 32, I can't speak to that.
NTFS is inherently a more robust file system
that FAT32-if you have qualms regarding compression,
you may want to consider converting to it
it you're not using it already.
However, you may not be able to if you're short
on free disk space-the conversion utility needs quite a big
chunk to do its work.
then again, NTFS compression is an 'in place' technique, which basically
means put the file on disk (original size) and *then* compress it.
this may contribute to your diskfiles becoming fragmented more rapidly.
just a consideration
"V Green" <vanceg@nowhere.net> wrote in message
news:%23b%23BS1dcEHA.2544@TK2MSFTNGP10.phx.gbl...
at
a
> > Regards
> > Dave
Thanks all.
Regards
Dave
"george" <anonymous@discussions.microsoft.com> wrote in message
news:eplQQLjcEHA.212@TK2MSFTNGP12.phx.gbl...
disk
| at
there
| a
| > > Regards
| > > Dave
BTW:
Easy to get round: backup, delete, compress the drive, restore. Or zip up as
much as possible, delete unzipped versions of the zipped files, compress the
drive, restore. :-)
BTW:
I suspect not as rapidly as on an uncompressed drive that is nearly full.
BTW
news:ubnsuHlcEHA.2812@tk2msftngp13.phx.gbl...
> BTW:
Not so, because 'compression' is just an 'attribute' of the files and
folders and not a characteristic of the drive.
So upon restore your files will be written to the disk in uncompressed form
and then, as I already said, compressed 'in place'.
>Or zip up as
the
> drive, restore. :-)
Hi George
news:uCT4jmucEHA.2816@TK2MSFTNGP11.phx.gbl...
form
I see what you mean, but presumably it would work if you only restored a few
folders at a time rather the whole lot at once?
'In theory' even with few at the time you would still end up with small
portions of free space in between the few files just restored/compressed.
So you might just as well restore the lot, indicate compress at root level
(+subfolders) and follow with a defrag
Mind you, why bother.
disk space being at prices it is these days, why incurr the extra process
overhead when accessing the files and writing/modifying them ('cuz it will
decompress n read and compress on write all the time).
If you really want to gain smoe space, just compress the stuff that's on
disk but rarely used.
Like in everyday life, whenever you gain someting somewhere, you're bound to
'pay for it' somewhere else.
So you gain storage space and pay in performance.
Is that noticable?
Depends on the strength of you machine.
It definitely is 'measurable'.
just my take on it.
george
news:ue5e2YvcEHA.2944@TK2MSFTNGP11.phx.gbl...
> Hi George
> form
few
> Regards
> Dave
