Solved
Possibel solution in processor problem
processor problem what are the possible solution
4 answers Last reply Best Answer
More about possibel solution processor problem
  1. Best answer
    Hi newcomer and welcome to the Tom's hardware forum.
    What exactly problem do you have with the processor?
  2. Best answer selected by gemai.
  3. the processor not working,cpu fan not working, broken pin,processor is not tightly inserted,what the best solution
  4. ^For the CPU fan, you can buy another one.
    For the pin broken, the best solution is buy another CPU. Maybe you can use the CPU with the broken pin, but this could ne unstable.
Motherboards Processors
