DVI problem
Forum Graphic & Displays : ATI - DVI problem
Hello
So I have ATI HD4550 and Samsung 205BW runing on W7 and CCC 9,8
So I had RGB for monitor and DVI for TV
Now I wanted to use HDMI for TV and DVI for monitor
The HDMI works fine, but I cant get the DVI to work under windows
when I start the computer the boot and the loading screen for windows work fine, but when it gets to start windows I get a black screen.
I can only get to work RGB and HDMI, but not DVI and HDMI
Any ideas on what to do or what could be wrong?
Sponsored Links
using the tv as your primary monitor go into display settings and turn on the other monitor, then set it as the default primary
------------------------------ E8400 : GA-EP35-DS3L : mushkin 4GB DDR2 800 : HD 2600PRO : 450W ATX12V : Windows 7
Reply to 505090
- 0 +
This didnt work, I still get a black screen. Also I noticed I get a blinking message that I should use 1680x1050 for this monitor, and yes I do use this but dosnt work.
Also I noticed that if I lower the resolution to 1280x1024 it works but the picture is corupted, twisted. so DVI works, digitial input works, and I dont know whhat is wrong
Any other ideas?
Reply to Malko
- 0 +
are you using a vga -> dvi adapter, not all monitors support that feature. You would have to check with the manufacturer about it.
Reply to 505090
- 0 +
If I use DVI-VGA adapter it works since the monitro then works on VGA cabel,
As I said it dosnt work if I use direct DVI to my monitor on 1680x1050, I get a mesage to ''set the resolution to optimum 1680x1050'' strange I know but dont know what is wrong
Any other Ideas?
Reply to Malko
- 0 +
so it's a straight dvi connection no adapters. Just to be though did you set the res to 1680x1050.
how is the tv hooked up dvi ->hdmi adapter
If you have two dvi ports on your card have you tried swapping ports
Reply to 505090
Are you running Windows 7? If so, I'm fairly certain it's an OS limitation. One of my friends just ran into the same type of problem, and after several hours of googling and foruming, that's the reason I've come up with.
EDIT:
It's an OS limitation with ATI GPUs. Nvidia GPUs supposedly work fine, but I don't have the ability to try it myself.
Message edited by jedimasterben on 09-03-2009 at 05:12:20 AM
Reply to jedimasterben
- 0 +
Ive had both the Win 7 RC and now RTM running off DVI on my last two moniters. the only thing that doesnt work is sound through DVI but i dont think that exists if i remember from my days of doing dish network installs. To me its wierd that my drivers show support for it though.
Although I am running a XFX 4850 on an LG TV monitor, here it is on newegg: http://www.newegg.com/Product/Prod [...] 6824005120
Message edited by decen on 09-03-2009 at 06:40:48 AM
Reply to decen
- 0 +
Well I dont think its the W7 since I have double OS with Win XP Pro, and it also dosnt work there. I am fairly certain that it could be the monitor not sure how and why, will take it to a friend to test it out
Also I have 3 outputs on my card
VGA
DVI-D
HDMI
Reply to Malko
- 0 +
VGA
DVI-D
HDMI
That could be the problem, you said vga works. Some monitors only take vga and and DVI-A which is the same signal just over a different cable. DVI-d is an entirely different signal.
I have talked to several people who have dual monitors in win7. The only thing is that unlike xp you can not run more than one separate video drivers.
Reply to 505090
- 0 +
This monitor takes DVI-D
I have used it with DVI some time ago, then switched to VGA because I used DVI for LCD Tv
now I have a new PC and i want to use DVI for monitor and HDMI for TV
Reply to Malko
My friend also had dual monitors, however they were both DVI, not mixing HDMI or VGA into it. It worked right up until the new video card got dropped in.
Also, I'm currently running an ATI 4870, with an Nvidia 8800GT for running PhysX, so yes, you can run multiple display drivers. http://en.wikipedia.org/wiki/Windows_Display_Driver_Model#Future_versions
- 0 +
So here is an update
I tryed on a diferent computer and the monitor works fine
So why isnt working here, when I send 1680x1050@60 to monitor I get a blinking message on it that I should use the native resolution 1680x1050@60Hz strange
But it works on lower resolution, why?
Any ideas any one?
Reply to Malko
- 0 +
did you try ressetting the drivers?
or maybe its the refresh rate, i have had issues with both but i dont remember what exactly caused it and what my old monitor did.
Message edited by decen on 09-03-2009 at 09:53:01 PM
Reply to decen
- 0 +
most lcds refresh at 60
Reply to 505090
- 0 +
I know, I wish i remembered exactly what my computer did, but when i switched video cards it caused issues with me going to DVI.
did you check the drivers?
Sorry I'm not much help....
Reply to decen
- 0 +
I dont know what else coul do or check
I tryed different drivers, curently I have the latest ones, did install//unistall a severeal times, still the same
Out of Ideas
any other ground braking ideas, I will be happy :)
Reply to Malko
- 0 +
So I did some more magic, I maneged to get it to work, partly
I clicked in CCC the ''DVI lower refrsh rate'' or something like that and it started to work but it still flickers, it turn on turns off etc...
so now I am sure that the problem are the drivers since the monitor works and the output works, tryed 3 diferent drivers and still the same
what else can I do?
Reply to Malko
Tom's Hardware > Forum > Graphic & Displays > ATI > DVI problem
There are 1071 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
