SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: DVD and eventually Bluray ripping, torrent downloading, HD playback and streaming to Popcorn hours, internet browsing and general multitasking
PARTS NOT REQUIRED: 27" Dell Ultrasharp Monitor, Case (Antec 900), 750gb HD, Keyboard and Mouse
PREFERRED WEBSITE(S) FOR PARTS: Newegg and Superbiiz
PARTS PREFERENCES: intel i7 CPU
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: Not sure I need this
MONITOR RESOLUTION: 1920x1200
ADDITIONAL COMMENTS:
I have been doing alot of research and I think I am ready to build my computer. I really don't know which graphic card to choose however. Please give me suggestions or comments on my picks
I will eventually get a hp mediasmart server to store all my media on, but in the meantime I will be using this computer. Do I need any addition parts, like a CPU cooler or is the stock going to be sufficient. Will a standalone network card be worthwhile or not. Is 6gb ram sufficient for ripping DVDs and Blurays or will I benefit for increasing RAM.
You wont need a gfx card as powerful as the 4850 .
Its really designed for 3d gaming and your use doesnt require that much power .
A 4670 is more appropriate , or equivalent nVidia card
You could even scale back the power supply to 500 - 550 watt since you wont have the heavy draw of a gaming card . The i7 is the best choice for your use . The stock cooler works but an aftermarket cooler might run quieter [ depending on what you buy ] Make sure you have a 64 bit version of windows or it wont be able to use all of your ram . $110 for vista 64 with an upgrade to the new version of windows thats being released in a few weeks
Oh yeah , microcenter sell the were/are selling the i7 920 for $199.99 . That might save you some money to
Message edited by Outlander_04 on 08-12-2009 at 11:45:07 AM
^+1. A 4670 or even 4650. Since you won't be gaming, consider a fanless model for quiet, but do make sure you have good airflow through your case. Without a gaming card, an Antec Earthwatts 380 would be enough to power your rig, although you might want a 430 or even a 500 for more headroom.
You will not need a separate network card, unless you need wireless.
Message edited by jtt283 on 08-12-2009 at 03:17:11 PM
You might want to scale back the PSU and GPU (possibly RAM also) and use that money for more storage, like the WD Caviar Green 1TB (i think they're $80 each right now on newegg).
