This is my first time building a computer with all new components--have only done refurbishments in the past.
I am using an Antec Sonata 3 case, Gigabyte GA-EP45-UD3P motherboard.
When installing the components, I placed the case on its side, with the access panel side facing up. I did several test boots with minimal components and they all went fine. Once everything was installed I was able to boot the computer, access BIOS, etc. However when I place the case the right way up, it will only occasionally boot, and only with the access panel removed. Most of the time the fans start, but there are no beeps, and everything cuts out for a second and then restarts. When placed on its side (including with the access panel on) it works perfectly and I was able to to install the OS and work normally on the computer.
Suggestions so far have been to tie the cables securely, remount the hard drive, and be more careful in pressing the power button. I've tried all of these, and there doesn't seem to be a difference. I've also tried leaving it unplugged for a lengthy time, and my perception is that this helps. This makes me suspect that's it's an electrical issue, but I don't know what would make it work lying on its side and not upright.
