Tom's Hardware > Forum > Homebuilt Systems > New System Build > [Solved] Need help with budget build (just some parts actually)
Forum Homebuilt Systems : New System Build - [Solved] Need help with budget build (just some parts actually)
Best answer from Outlander_04.
My friend asked me to help him build a computer with $200 - 250 budget and some parts he had. He already got this motherboard (ZOTAC LGA 775 NVIDIA GeForce 9300)
http://www.newegg.com/Product/Prod [...] 6813500019
APPROXIMATE PURCHASE DATE: ASAP
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: school work, internet, some gaming (not for high-end games)
PARTS NOT REQUIRED: motherboard, RAM, hard drive, and monitor
PREFERRED WEBSITE(S) FOR PARTS: newegg, tigerdirect, frys.com
PARTS PREFERENCES: Intel platform because he already got a LGA775 mobo.
OVERCLOCKING: no
Almost all low-end build plans in this forum I found used AMD platform, so please help me with a Intel low-end suggestion.
I guess he can use the on-board graphic for a while since it's a GForce 9300.
Basically, he needs a CPU, Case+PSU, DVD-rom or burner.
Thank you very much!
Message edited by beef1218 on 08-13-2009 at 10:12:17 AM
oh well .
your processor choices are the same . so
Intel Core 2 Duo E7400 Wolfdale 2.8GHz $115
http://www.newegg.com/Product/Prod [...] 6819115206
and SATA dvd/cd drive for around $28 on newegg
A very good budget gaming case with psu
Antec Three Hundred Black Steel ATX Mid Tower Computer Case +Antec earthwatts EA430 430W Continuous Power ATX12V combo is $99.94
http://www.newegg.com/Product/Comb [...] mbo.216944
Thats $242.93
but you can scale back the processor to e5300 , e5400 , e6300 and reduce the cost
Sponsored Links
the intel budget processors are very good cpus
you should look at the e5200 or e7400 or e7500 .
Case is all about personal choice . I prefer more conservative styled cases and other perfer thing that look like they were rejected from a star trek movie because they looked like they came from way way way too far into the future .
His motherboard is interesting though because it is mini itx , which is a really specialist area .
On the mb's newegg page [ in a combo ]is this case
SILVERSTONE SG06-B Black Aluminum/SECC Mini-ITX Desktop Computer Case SFX 300W with 80 PLUS certification Power Supply
http://www.newegg.com/Product/Prod [...] 6811163151
or the cheaper steel case that seems to be identical
SILVERSTONE Sugo SG05-B Black SECC Steel Mini-ITX Desktop Computer Case SFX 300W 80Plus Power Supply
He could probably choose anything from here as well
but it will need a mini itx psu if one isnt fitted
You will need a SATA dvd drive . And depending on the case it may have to be half height
e5200 ~ $70
silverstone steel case $75 after rebate
sata dvd burner half height .~ $50
Some on this page are only dvd's and not cd's
http://www.newegg.com/Product/Prod [...] D%20Burner
Reply to Outlander_04
Outlander_04, thank you very much for your reply.
I'm very sorry that I made a mistake. I post the wrong link of the mobo. It's not itx board. Now I've fixed the link.
Reply to beef1218
Best answer
oh well .
Thats $242.93
DVD drive: my first choice is Samsung, closely followed by LG. I've had a couple of LITEON's fail at the 10 month to a year point.
Reply to jsc
Thank you everyone for your help.
I think I will go with the E5200.
Reply to beef1218
There are 944 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
