B buggefish Distinguished Jan 30, 2010 2 0 18,510 Jan 30, 2010 #1 Hello my wireless network has two network connection connected. is this correct
G Guest Guest Jan 30, 2010 #2 Does it have any obvious effect ? If not, it probably doesn't matter. In fact, one may be the wired NIC. You could just delete one and see what happens. Upvote 0 Downvote
B buggefish Distinguished Jan 30, 2010 2 0 18,510 Feb 6, 2010 #3 if i disable one i lose my connection. i disable the upnp setting on my network and it has not happen since Thanks Upvote 0 Downvote
elel Distinguished Jun 18, 2009 1,042 0 19,360 Feb 6, 2010 #4 Good idea. I've heard that that UPNP is a good threat vector, so if you can turn it off and solve your problem at the same time that an extra treat. Upvote 0 Downvote
