Lutfij Titan Moderator Oct 7, 2009 54,048 4,741 173,390 Feb 4, 2010 #1 hey all! can u guys help me with this? should i get the asus rampage formula or the maximus II formula/gene any help is appreciated! Thanx
Solution saint19 Feb 4, 2010 Ok. The maximus II is a micro-ATX, that IMO isn't good for a good rig. So, I would get the rampage. P.D. The LGA 775 is a old socket, if you want a good rig, try to go with a i3 or better or AMD AM3
saint19 Polypheme Mar 20, 2009 15,746 26 60,540 Feb 4, 2010 #2 Hi. What components do you want install in the mobo? 1- CPU 2- RAM 3- HDD 4- GPU Upvote 0 Downvote
Lutfij Titan Moderator Oct 7, 2009 54,048 4,741 173,390 Feb 4, 2010 #3 CPU - E8400 GPU - 5770 or higher mite even settle with the 4890 i have 2GB DDR2 800+ Transcend but i could get 4GB DDR2 transcend 1066+ or any good overclocking rams of your advising HDD already exist from prev rig 500GB WD but i'l change for higher PSU for GPU Upvote 0 Downvote
saint19 Polypheme Mar 20, 2009 15,746 26 60,540 Feb 4, 2010 Solution #4 Ok. The maximus II is a micro-ATX, that IMO isn't good for a good rig. So, I would get the rampage. P.D. The LGA 775 is a old socket, if you want a good rig, try to go with a i3 or better or AMD AM3 Upvote 0 Downvote Solution
Lutfij Titan Moderator Oct 7, 2009 54,048 4,741 173,390 Feb 4, 2010 #5 in that case do u think i should go for the crosshair III formula? Upvote 0 Downvote
saint19 Polypheme Mar 20, 2009 15,746 26 60,540 Feb 4, 2010 #6 Yea, the Crosshair III is a very good mobo, but remember that is for AMD processors. Other options are the MSI 790FX-GD70 or ASUS M4A79 Deluxe. Upvote 0 Downvote
Lutfij Titan Moderator Oct 7, 2009 54,048 4,741 173,390 Feb 4, 2010 #7 hmmmm....is there anything higher than the 965 BE? Upvote 0 Downvote
saint19 Polypheme Mar 20, 2009 15,746 26 60,540 Feb 4, 2010 #8 None, the 965 is the top of the AMD, can't defeat the i7 and sometimes lose with the i5, but can defeat all series of C2Q except the C2Q Extreame. Upvote 0 Downvote
Lutfij Titan Moderator Oct 7, 2009 54,048 4,741 173,390 Feb 4, 2010 #9 Best answer selected by Lutfij. Upvote 0 Downvote
Lutfij Titan Moderator Oct 7, 2009 54,048 4,741 173,390 Feb 4, 2010 #10 then i suppose theres no point in salvaging the parts from my old rig E4300 :S might as well sell it huh, or should i jus network it (pc-pc)? Upvote 0 Downvote
