That motherboard and the PSU you picked will allow adding another 4870 1GB card in crossfire later. You could even go down to the 750TX and have enough power for crossfire 4870's.
Message edited by shortstuff_mt on 08-13-2009 at 10:00:47 PM
Sorry, I'm at work and they block access to amazon.com so I couldn't see what RAM the OP was planning on using. I wouldn't suggest DDR3 on an LGA 775 socket build. Quality DDR2 800 RAM is all that's needed for a Core 2 setup.
I agree that it makes no sense to use a Core 2 chip for a new build. AMD currently offers better price/performance as well as an upgrade path. LGA 775 is dead.
If the OP uses the template at the top of the forum and posts a request for assistance putting a build together at a specific budget, I'm sure we could put something better than the above together.
Message edited by shortstuff_mt on 08-13-2009 at 10:34:23 PM
I wouldn't recommend DDR3 RAM for an Intel Core 2 build. In fact, I wouldn't recommend an Intel Core 2 build at all at the moment. AMD makes much more sense right now.
Do you already have the above components? If not, what is your budget and what do you plan on using this build for? We can do much better.
Okay I will come up with a great AM3 build for around $1000. Do you need a monitor, keyboard, OS, and mouse? I will post a build with just the main rig for $1000 and edit it if needed.
edit: Haha nice shortstuff! that is a very solid build and I would have recommended basically the same build. The only thing that the OP could change is the 4870 1gb. You could upgrade it to a 4890 for about $40-50 more. Again that is really up to you but shortstuff's build is extremely solid!
Message edited by waynec121 on 08-13-2009 at 10:47:01 PM
------------------------------Fire Protection Engineering Major @ UMCP
Why do you want to do an Intel build? I don't have a preference between Intel and AMD. It's just not a good time to build an Intel system at the $1,000 price point. Intel is in the process of killing the Core 2 chips to make way for the new mainstream chips. Core 2 lived a good life, but there are currently better options out there for your money.
You still haven't said what the intended use of this computer is. Without knowing that, the Intel i7 920 is the only Intel chip I'd use at the moment. It's hard to squeeze an i7 build into a $1000 budget without cutting more corners than I'm willing to cut. The above AMD build is your best option with a $1000 budget.
okay then the AMD build will serve your needs just as well as the i7 would if you are going to be gaming. If you are using CS4 or doing hardcore HD video editing then I would recommend the i7 but for your uses the AM3 build would serve your needs great.
Yes, I'm absolutely sure that AMD is the way to go in this price segment. The fact that you "really like" Intel and the you've "always used" Intel doesn't mean they're better.
You can check the benchmarks for the games you intend to play if you don't want to take my word for it. AMD is currently very strong in the mid-range segment.
Message edited by shortstuff_mt on 08-13-2009 at 11:07:44 PM
