OpenGL problem on Sony Z1VA
Forum Laptops & Notebooks : General Laptops & Notebooks - OpenGL problem on Sony Z1VA
Archived from groups: comp.sys.laptops,comp.graphics.api.opengl (More info?)
I recently bought a Sony VAIO Z1VA with XP Home preinstalled.
It came equipped with ATI Mobility Radeon graphics.
The ATI Radeon details:
OpenGL
ATI Radeon 7000 DDR x86/SSE2
Version 1.3.3413 WinXP Release
Video Adapter
16MB Video, 56MB AGP
Texture Memory 72MB
Video Driver: ati2mtag.sys
Version: 6.13.10.6243
Before layering applications onto the machine I upgraded the
OS to WinXP Pro/SP1 + several Sony OEM drivers reapplied to
enable the NIC, WiFi, and etc.
Now I find that OpenGL performance is so slow and jerky/choppy
as to be useless. Windows OpenGL screensavers skip and jump around;
Sketchup 3.3 (an OpenGL based design program) freezes for seconds at a
time when hardware acceleration
is turned on.
The adapter looks OK to both the system (Control Panel/System/Hardware),
and to SisSoft Sandra. I'm also able to make setting through the ATI
OpenGL driver settings tab. Yet, OpenGL performance its totally hosed up.
What could be causing this?
Sponsored Links
> OpenGL
> Video Adapter
> Texture Memory 72MB
> is turned on.
> Panel/System/Hardware), and to SisSoft Sandra. I'm also able to make
> setting through the ATI OpenGL driver settings tab. Yet, OpenGL
Disk cleanup, defrag, review startup apps in msconfig, try it again.
New installs are problematical until cleaned up. You also do not
mention RAM. XP runs well in 512. Cleaned up, 256MB is "adequate".
Anything below 256MB requires attention to every detail.
Q
Reply to Anonymous
>>OpenGL
>>Video Adapter
>>Texture Memory 72MB
>>is turned on.
> Q
Thanks for the help.
Disk is very clean -- trying to avoid clutter slowdown like on my
desktop. Defrag very often to keep up performance. As for startup
apps, that too is strictly controlled via Startup Cop.
The laptop came with 512MB of DDR memory.
In general, XP runs very faast on it. In fact it runs just about every
application faster than my 1GHz AMD desktop; everything except for OpenGL.
I think there's something more fundamentally wrong with my
configuration, but I'm not familiar enough with OpenGL on XP to
have a clue -- yet.
Reply to Anonymous
>>> OpenGL
>>> Video Adapter
>>> Texture Memory 72MB
>>> at a time when hardware acceleration
>>> is turned on.
>>> make setting through the ATI OpenGL driver settings tab. Yet, OpenGL
>> Q
> every application faster than my 1GHz AMD desktop; everything except
> for OpenGL.
> have a clue -- yet.
Reinstall the video driver. Are you using the Sony ATI driver or the
Catalyst with the mods for installation? If I recall correctly, on my
new GRV-670 the OpenGL screensavers were erratic. I think it went away
with a driver update from Sony. Mine has Radeon 9000; I've used both
the Sony driver and the modded Catalyst without noting any difference.
If Sony has not updated the 7000 driver, then the modded Catalyst might
be a better choice. I would do the reinstallation of the Sony driver
first though. Also, check that the Indexing service is turned off.
Q
Reply to Anonymous
> OpenGL
> Video Adapter
> Texture Memory 72MB
> is turned on.
I had similar trouble with my VAIO (mobility Radeon 7500), OpenGL
performance was poor and it was not refreshing the extended desktop. New
drivers from Sony did not help at all.
I downloaded the latest Catalyst drivers from ATI and a little tool
called Dhmodtool2.0. This tool enables installation of Catalyst drivers
for the Mobility range. The process is as follows:
- start Catalyst setup (it will unzip into c:\ati directory)
- once Catalyst tells you that it cannot install because you don't have
compatible hardware, start the Dhmodtool and install the drivers through
its GUI
It worked fine for me and OpenGL is now quite perky.
If it doesn't work for you, I hear there are unofficial Omega drivers
for ATI cards that solved problems of lots of people, I haven't tried
them myself.
Reply to Mauricio
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > OpenGL problem on Sony Z1VA
There are 1147 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 heli0s won the Freshman badge
  • 14:45 trinix won the Sophmore badge
  • 01:00 citywill won the Uniformed badge
  • 01:00 Tameas won the Uniformed badge
  • 01:00 themeanmachine won the Uniformed badge
  • 01:00 taavi won the Uniformed badge
  • 01:00 mikrouwel won the Uniformed badge
  • 01:00 noiz won the Uniformed badge
  • 01:00 herojig won the Uniformed badge
  • 01:00 mrcmark won the Freshman badge
