Tom's Hardware > Forum > CPU & Components > Other Components > Help me determine what is running so hot!
Forum CPU & Components : Other Components - Help me determine what is running so hot!
Ok so I recently built a new computer and I wanted to see how all my temps were so I installed speedfan and I was extremely worried with one of them! Speedfan is recording something as 127 degrees C. Now that's melting temps, so I immediately shut down my comp to go into my BIOS/CMOS and saw that my CPU was running at 39 degrees C and my motherboard was at 33 degrees C. Also my GPU idles around 35 degrees and my hard drive is at 30 degrees C. So i have no idea what speedfan is recording so high. It's Temp 3 for IT8720F.
Here's my build:
Core i7 920
ASRock Extreme x58
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Model F3-12800CL9T-6GBNQ
HIS Radeon HD 5870
WD Black Caviar WD1001FALS 1TB
CORSAIR CMPSU-850TX 850W
Thermaltake Element S case
Message edited by prunestida on 11-08-2009 at 05:10:58 PM
Sponsored Links
Windows will crash at about 75c, so if your system is stable and you get these high temps, don't believe them. I use coretemp. I had alot of accuracy issues with various software; stopped using it for a long time. I recently went back to coretemp so I could monitor a dual core amd on a sempron heatsink. Both cpus are rated at 45 watts, so I decided to skip a heatsink upgrade.
Message edited by o1die on 11-08-2009 at 06:16:32 PM
Reply to o1die
127C means that there is likely no temperature sensor for it to get a reading from. Nothing is running hot, it is just trying to get data from a sensor that doesnt exist. Not all motherboards have all of the possible temperature sensors.
Reply to hunter315
------------------------------ If a man speaks in the forest and no woman hears him, is he still wrong ?
Reply to JackNaylorPE
Ok thanks, hopefully nothing is running that hot in my system lol.
Reply to prunestida
Jack,
Nice catch! :D
prunestida,
If you'd like to learn more about processor temperatures and SpeedFan, then just click on the link in my signature. ;)
Comp :sol:
Reply to CompuTronix
There are 1157 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
