Ok first off here's my system....
Blu ray drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136232
Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
GPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121390R
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130235
PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817152036
Ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145262
2 seagate hdd's , 1 160 gig as the main boot disk and a 500 gig that has Steam and most of my games on it.
Well my problem arises when I try and overclock my Gpu. I used the software that came with the card and I've tried MSI afterburner. Anything more than a few increments above the regular 700mhz core clock causes the 2nd hard drive to not be recognized, it took me forever to figure out that the gpu overclock was causing it as I had just thought the hard drive had just bit the dust, upon removing the oc, everything went back to normal. I've tried again a few times to make sure that was the problem and the same thing happens. Now I'd hate to have to keep going in there and switching sata cables around to see if it's a certain port thats conking out (why the hell should I have to do that anyway) but has anyone else ever encountered such a problem? And is there a simple solution? Or is my motherboard or some other component just a pos that I should replace. I know I don't have a super high end power supply but it's served me well for a while.
Blu ray drive
Case
GPU
CPU
Motherboard
PSU
Ram
