Tom's Hardware > Forum > Graphic & Displays > ATI > Problem with DVI Connection to my PC with Samsung P2350
Forum Graphic & Displays : ATI - Problem with DVI Connection to my PC with Samsung P2350
Hi i just got my New Samsung P2350 today from ebuyer. I got it all set up fine and everything but when i connected my PC to the monitor. The monitor doesnt recognise my computer. It just says "Check Digital cable" on the screen repeatedly. Ive tried litrally everything. Changed DVI cables, Got the Latest ATI drivers, Installed all the drivers and softweare with the disc it came with. Everything :( But nothing. I have plugged my xbox 360 with the VGA HD cable and it works flawlessly. My computer will connect to my samsung TV and my older monitor fine so im pritty sure its not my computer. ( at least i dont think so). Any help would be most Appreciated thanks :)
PC specs:
AMD 6000+ 3.0ghz
2GHz RAM
ATI 4850 512mb Powercolor
M2N-e Motherboard
Windows XP home Edition 32bit
Catalyst drivers 9.8
And both Analogue and digital Drivers installed for the monitor. :S
Thanks for your time :)
Sponsored Links
You may have tried this. Is the DVI cable plugged into the monitor correctly? I often have to make sure the pins are lined up the right way. Bent pins are a real pain to fix.
Reply to sprucebr1
yeh there prefectly fine and fitted in firmly.
Reply to Benjamin18
I have the same problem. Anyone knows?
Reply to Anonymous
There are 1165 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
