Problem while running XP's disk compression utility
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
I started off Windows XP's disk compression utility and not long after it
started, I got the following message:
______________________________________
"Error Applying Attributes
An error occurred while applying attributes to the file:
....\7a436fe806e48396f48a894af2fe9a1_99eeeoc3-2ff-4e1
Access is denied.
[Ignore] [Ignore All] [Retry] [Cancel]"
What does this mean and what should I do?
Regards
Dave
It could mean the file is in use. I would cancel the procedure and
decompress the files already done. If free space is limited, you'd better
purchase the larger capacity disk.
Ask the community
