Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > I7 system nearly finished - advice please
Forum Systems : New Build I7 system nearly finished - advice please
This is what I got at the moment, some parts are from my old system.
I am seeking opinions and advice.
PREFERRED WEBSITE FOR PARTS: any
PARTS NOT REQUIRED: (keyboard, mouse,OS,speakers,sound card,)
PARTS PREFERENCES: any (quality + value for money)
OVERCLOCKING: Yes
SLI OR CROSSFIRE: Yes
will be used for gaming , photo&video editing , general home
OS vista x64 ultimate (but windows 7 will be added ) so 2x OS
CASE: THERMALTAKE SOPRANO BLACK
http://www.eclipsecomputers.com/pr [...] AT-XSOPWBK
CASE FANS: 2X 12cm standard fans (front+back) + 1x 9cm standard fan (side) (SHOULD I CHANGE fans???)
MOTHERBOARD: ASUS P6T DELUXE V2
http://www.eclipsecomputers.com/pr [...] BA-P6TDEL2
CPU: intel i7 920 d0 (2.66)
http://www.eclipsecomputers.com/pr [...] PI-I7920D0
CPU COOLER: STANDARD INTEL CPU COOLER (WILL BE CHANGED within next few days)
MEMORY: OCZ Reaper6Gb DDR3 1866MHz (3x2Gb) Tri-Chanel
http://www.eclipsecomputers.com/pr [...] D3-6144R18
PSU: SEASONIC M12D - 850W
http://www.eclipsecomputers.com/pr [...] SS-850M12D
FAN CONTROLLER: ZALMAN ZF-MFC2
http://www.eclipsecomputers.com/pr [...] e=HFZ-MFC2
GRAPHIC CARD: NVIDIA GEFORCE 8600GT 512MB (WILL BE CHANGED within next few days)
SOUND CARD:CREATIVE AUDIGY 2ZS
ONBOARD AUDIO: ADI AD2000B 8 -Channel High Definition
SPEAKERS: CREATIVE INSPIRE T7900 7.1
HDD1: WESTERN DIGITAL WD6400AAKS 640GB
http://www.scan.co.uk/Products/640 [...] ache-89-ms
HDD2: WESTERN DIGITAL WD2500JD 250GB (WILL BE CHANGED within next few days)
DVDRW: PIONEER DVR-216
monitor: (using lcd tv - sharp aquos 37" 1920x1080) new monitor will be purchased 1-2 months later
Question1:
Should I change case fans???
Question2:
cpu cooler: thinking to get: Prolima Megahalems Super 6 Heatpipe Tower Cooler + 12cm fan? (good choice?)
http://www.scan.co.uk/Product.aspx [...] ID=1040994
tests:
http://benchmarkreviews.com/index. [...] mitstart=7
question3:
graphic card: I'm thinking about - xfx 896Mb nVidia GeForce GTX 275 AMP
http://www.scan.co.uk/Products/896 [...] x-DL-DVI-I
tests:
http://www.videocardbenchmark.net/high_end_gpus.html
question4:
hdd2: WESTERN DIGITAL WD6400AAKS 640GB - ( raid0 for better speed? )
or second faster hdd?
Please let me know about my mistakes!!!
Thanks for your help.
Message edited by white27 on 08-18-2009 at 12:31:55 AM
Reply to white27
Looks good, but there are some changes that you need to do.
The case you selected will have a problem with airflow for cooling purposes and also with the side door fan getting in the way of most aftermarket CPU coolers'.
Below are some cases I found at the same site you had your pick at that should do.
Mid Tower
CoolerMaster HAF 922 Black ATX Case, No PSU £83.89 inc.VAT
http://www.eclipsecomputers.com/pr [...] CAC-HAF922
CoolerMaster Storm Scout Black ATX Gaming Case, No PSU £76.48 inc.VAT
http://www.eclipsecomputers.com/pr [...] AC-SGC2000
Full Tower
Antec Twelve Hundred Gamers Case, ATX, No PSU £134.26 inc.VAT (excellant airflow)
http://www.eclipsecomputers.com/pr [...] e=CAA-1200
If you are planning to Raid your HHD's I would suggest this one and if not Iwould suggest you get a 2nd HDD of the one you picked as storage.
750 GB Western Digital WD7502ABYS RE3, SATA 3Gb/s, 7200rpm, 32MB Cache £87.73 Inc VAT
http://www.scan.co.uk/Products/750 [...] rprise-HDD
The Ram you picked will interfere with Aftermarket CPU Cooler, check thes out below.
Corsair Dominator DHX 6Gb DDR3 1600 (3x2Gb) Tri-Chan Kit £112.99 inc.VAT
http://www.eclipsecomputers.com/pr [...] D3-6144D16
Also @ Dabs for £105.38 inc vat Free delivery available
http://www.dabs.com/products/corsa [...] 1974-50113
OCZ Technology DDR3 6GB (3x2) Platinum 1333Mhz CL7 (7-7-7-20) £90.34 inc vat Free delivery available
http://www.dabs.com/products/ocz-t [...] 1974-50121
Now your choice of CPU Cooler is one of the top5 for Core i7, but you have to buy fan for it, check out these two.Thermalright Ultra-120 eXtreme 1366RT 120mm heat sink KIT for Intel 1366 CPU inc 1600RPM fan £51.62 Inc VAT
(is the top dog)
http://www.scan.co.uk/Products/The [...] 600RPM-fan
Cogage True Spirit 120mm PWN Fan Covering 48x Alum fins with 4x Copper Heat Pipes £32.19 Inc VAT
(designed by Thermalright and runs a few degrees hotter then Thermalright Ultra-120 eXtreme 1366RT)
http://www.scan.co.uk/Products/Cog [...] -1366-Cpus
Review you should check out.
http://www.hardocp.com/article/200 [...] dup_q309/5
Items you will need
Chill Factor 2 (4g) - Thermalright Chill Factor 2 £5.74 Inc VAT
http://www.scan.co.uk/Products/The [...] rming-T-P)
You will need this 8-pin Power Extension Cable for most Cases that has Bottom Mounted PSU.
Akasa 8-Pin 30cm PSU Extension Cable £3.44 inc VAT
http://www.overclockers.co.uk/show [...] 48&subcat=
Hope this helps out some.
Message edited by Yoosty on 08-15-2009 at 03:50:17 AM
Reply to Yoosty
I've heard negative reviews of Zotac GPUs (the quote below is from newegg, the exact card you linked from a different vendor). I'd suggest EVGA or XFX, the same GPU on the card, GTX 275 896mb is a great unit, just get a higher quality brand.
"Cons: I have only had this card for about 3 months before it died. Tech support is very poor. It is difficult to get through to a live person. When calling tech support I was automatically placed on hold then their automated phone system would hang up on me. It took me several days of calling until I finally was able to talk to a real person. The tech support person was not very friendly. I sent them the card over a month and have yet to receive my warranty replacement video card. "
------------------------------ Core i7 920 2.6GHz | Asus P6T Deluxe V2 | EVGA GTX 275 896mb | G.Skill Sniper DDR3 1600 12gb | Corsair 850TX | OCZ Vertex Plus 120gb SSD + Caviar Black 2tb | Antec 900 | Samsung 25.5\" HD Rose Black and 19\" Syncmaster dual monitor
Reply to lehighace06
try using OCUK or scan instead of eclipse computers, the prices are a bit better.
Reply to Helloworld_98
- 0 +
OP misnamed Graphic card as one from Zortac but it is one from XFX if you went to link.
GX-275X-AHDA - 896MB XFX GTX 275 XXX 55nm, 2268MHz GDDR3, GPU 670 MHz, Shader 1404 MHz, 240 Cores.
Quote :
helloworld_98
Most are from others sites, but that will be remedy right now.
Only one case is cheaper and that is by £1.51 quid. But did find some lower prices on the following parts.
CPU
Intel Core i7 920 D0 Stepping (SLBEJ)This Week Only Offer £201.99 inc VAT (was £204.99 inc VAT)
http://www.overclockers.co.uk/show [...] ubcat=1272
BX80601920 - Intel i7 920, D0 SLBEJ £201.45 Inc VAT
Mobo's
Asus P6T DELUXE V2 S1366 Intel X58 ATX A L CF/SLI £203.75 inc vat Free delivery available
http://www.dabs.com/products/asus- [...] 0000-50626
Asus P6T Deluxe V2, Intel X58 £202.60 Inc VAT
http://www.scan.co.uk/Products/Asu [...] 00(OC)-ATX
Reply to Yoosty
There are 1637 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
1400-1800 range, first build, need feedback
By Hopz, 5 hours ago:
I would keep the 750W for future upgrades and possible SLI in the future. Will save you...
Best offers
Top experts
