AMD System Build!?!?
Forum Homebuilt Systems : New System Build - AMD System Build!?!?
Hey just ordered some new parts for a new pc....
AMD Phenom II x2 550 3.1GHz
corsair XMS 4gb DDR2 800 MHz Ram
Gigabyte MA720-US3 AM3 Motherboard
Sapphire Radeon HD4850 512mb
Enermax 535 duel rail PSU
IMO its a good budget build.... But!
My question is....
How well would this build run with GTA IV and Crysis? High settings? (not max) decent resolution?
I know i will be able to run things like , farcry 2, assassins creed on max pretty easily but yeh im not sure on gta 4 and crysis because they are very demanding.
cheers!
Sponsored Links
Crysis, yeah high settings without AA @ 1900x1200
GTAIV, well, you actually need a quad core to play it so not so much.
Reply to Helloworld_98
Well you don't NEED a quad, some duel cores do perform well under it. but good news for crysis. thanks for the response hopefully i preform better than expected for gta ! :D
Reply to instantcoffee
GTA4 is really optimized for a quad core.
I think you would have been better suited with a 720BE w/ddr3 on a AM3 platform. It only would have cost you about another $40 and your future upgradability would be much better.
Message edited by zipzoomflyhigh on 08-15-2009 at 04:54:57 PM
Reply to zipzoomflyhigh
Tom's Hardware > Forum > Homebuilt Systems > New System Build > AMD System Build!?!?
There are 1164 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
