Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > One more question on CPU cooler and case
Hi once more.
I am putting together the parts for my new I7 build.
I am leaning towards this case
LIAN LI Lancool PC-K62 Black 0.8 mm SECC, Plastic + Mesh ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Prod [...] 6811112239
Right now it is out of stock.
This is the motherboard I want
ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Prod [...] 6813131365
This is the CPU cooler I like
COOLER MASTER V8 RR-UV8-XBU1-GP 120mm Rifle CPU Cooler - Retail
http://www.newegg.com/Product/Prod [...] 6835103055
This is the Ram I wish to purchase
OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3G1600LV6GK - Retail
http://www.newegg.com/Product/Prod [...] 6820227365
I will be doing some mild overclocking. Right now I will stick with fan cooling as I have never installed water cooling.
Will this combination of Case + Motherboard + CPU Cooler fit?
Will the size of this CPU Cooler cause any issues with ram installation?
I know this is a large CPU cooler and I do not wish to make any modifications to the case in order to get it to fit.
If this will not work together, could someone suggest a case that would?
Please keep in mind I would like to keep this a mid-size case. I would also like to have a clear side so that I may see inside.
Thanks in advance
Sponsored Links
I am installing an I7 920
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail
http://www.newegg.com/Product/Prod [...] 6819115202
Along with 2 GTX 260 core 216s in sli
EVGA 896-P3-1257-AR GeForce GTX 260 Core 216 Superclocked Edition 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI ... - Retail
http://www.newegg.com/Product/Prod [...] 6814130433
Reply to mail4youtoo
Make sure you get atleast 650 watt power supply from a good brand like antec, corsair, seasonic, pc power & cooling, or ocz to power those two GPUs with.
Reply to hunter315
There are 1038 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
