Tom's Hardware > Forum > Homebuilt Systems > New System Build > Are there any conflicting parts in my rig
Forum Homebuilt Systems : New System Build - Are there any conflicting parts in my rig
I put together a gaming rig that I believe works well and is pretty cheap. Now I need a few people to look over it and make sure I'm not getting any conflicting parts.
Antec Three Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811129042 $59.95
AMD Phenom II X3 720 2.8GHz 3 x 512KB L2 Cache 6MB L3 Cache Socket AM3 95W Triple-Core Black Processor
http://www.newegg.com/Product/Prod [...] 6819103649
Antec TruePower New TP-550 550W Continuous Power ATX12V V2.3 / EPS12V V2.91 SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Active PFC
http://www.newegg.com/Product/Prod [...] 6817371020
GIGABYTE GA-MA770T-UD3P AM3 AMD 770 ATX AMD Motherboard
http://www.newegg.com/Product/Prod [...] 6813128392 $84.99
Patriot Viper 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model PVS34G1600LLK
http://www.newegg.com/Product/Prod [...] 6820220285 $84.99
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Prod [...] wd6401aals $74.99
SAPPHIRE Vapor-X Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
http://www.newegg.com/Product/Prod [...] 6814102825 $149.99
SAMSUNG DVD Burner Black SATA Model SH-S223L LightScribe Support
http://www.newegg.com/Product/Prod [...] 6827151188 $28.99
Acer X223Wbd Black 22" 5ms Widescreen LCD Monitor 300 cd/m2 2500:1
http://www.newegg.com/Product/Prod [...] 6824009145 $139.99
Sponsored Links
Everything looks good! The only suggestion I would have is to upgrade your PSU to a 750 watt Antec, Corsair or PC Power&Cooling to allow for you to Crossfire down the road. Your PSU is good for one GPU but not for two GPU's.
------------------------------ Recommended Builds by Usage
Step-by-Step Guide to Building a PC
Reply to tecmo34
Looks good, solid build.................. the AM3 770 can't crossfire.
Reply to dirtmountain
Good catch I missed that
Reply to tecmo34
i think this am3 board can crossfire and its not much more than your 770
http://www.newegg.com/Product/Prod [...] 6813131398
Reply to lebaneseguy
^ Only at 16x/4x
This Asrock AM3 780G does do 8x/8x crossfire though for $90, i'm not a huge fan of crossfire though, I usually replace a GPU when it fails to perform well enough and sell it. Then get a better performing GPU.
http://www.newegg.com/Product/Prod [...] 6813157161
There are 1271 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
