Tom's Hardware > Forum > CPU & Components > Other Components > Audio Cables for Gigabyte GA-M785GPM motherboard
Forum CPU & Components : Other Components - Audio Cables for Gigabyte GA-M785GPM motherboard
I just installed this m/b but the audio connections don't seem to work with my RCA cables. Any idea what type of cables I'm supposed to use? Many thanks in advance!
Sponsored Links
You should use 1/8 inch minijack connectors. What are you trying to do? Hook this up to a home theater system?
I'm assuming you mean this is an RCA cable: http://www.newegg.com/Product/Prod [...] -_-Product
What you would need is this: http://www.newegg.com/Product/Prod [...] 6882339159
What you're saying sounds like you're trying to put an RCA connector in a minijack port. That's like trying to jam a USB connector into an Ethernet port...
That cable would go into your GREEN port in your MB. Also, make sure your audio drivers are installed properly (put in the CD that came with the MB and run automated install of chipset drivers).
Hope that helps! :)
------------------------------ http://www.speedtest.net/result/594200256.pnghttp://www.pingtest.net/result/3492303.png
Reply to zinosys
There are 1205 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
