Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > What is the voltage capacity of exhaust fan within the power computer case
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - What is the voltage capacity of exhaust fan within the power computer case
The power supply case within the computer is functioning but the cooler or heat exhaust fan is not working when connected to the mother board but when we remove and test the fan it worked. What is the cause? or any remedy to to this grieve. Can I cut the two wires and connected to where? is t 12 volts?
Sponsored Links
So, let me get this straight. Your power supply is working, but the power supply's internal fan is not working?
Well, you just voided the warranty by taking it apart...
All fans (except server fans) are 12 volts...
------------------------------ http://www.speedtest.net/result/594200256.pnghttp://www.pingtest.net/result/3492303.png
Reply to Zinosys
Quote :
@OP: Please clear us up on exactly what you are doing. Also, what brand/model PSUs? Dying/bad fans are a common indication of cr@ppy PSUs.
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to shadow703793
There are 625 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 raulkm won the Uniformed badge
  • 01:00 letus won the Uniformed badge
  • 01:00 pmiddy won the Uniformed badge
  • 01:00 MarcieMark won the Uniformed badge
  • 01:00 kaypeezee won the Uniformed badge
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
  • 01:00 Kevinator won the Uniformed badge
  • 01:00 adis won the Uniformed badge
