System Recs please Noobs first build
Last response: in Systems
August 17, 2009 11:02:59 AM
APPROXIMATE PURCHASE DATE: with in a month
BUDGET RANGE: 400-450
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: GAMING, p**n, photoshop, internet
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers, OS, DVD DL burner
PREFERRED WEBSITE(S) FOR PARTS: newegg.com, amazon
PARTS PREFERENCES:
AMD and MATX Compatible
OVERCLOCKING: Maybe if possible with build SLI OR CROSSFIRE: Sounds cool so maybe if possible (REALLY DONT KNOW WHAT THIS MEANS)
MONITOR RESOLUTION: 1080? <----- Yes I'm a noob
ADDITIONAL COMMENTS:
Currently a console gamer trying to convert to the darkside of gaming
Here is what I have bought so far
Case = Paid $23
PSU = Paid $30
-------Going to Buy--------------------
CPU = 119
Mothersboard $69
HDD = $55
TOTAL SO FAR $296
$154 left to spend if I go more my wife will kill me ....JK maybe could go to $175
---------------- THIS IS WHERE I GET STUCK ----------------------
Not sure what memory and how much to get
also
Not sure what vidcard to get.
Please anyone that can give me some good rec's and also let me know if I'm on the right track or will this thing explode with what I have planned to put together
August 17, 2009 12:12:00 PM
you using 32bit or 64bit operating system? should be using 64 bit but you need to let us know.
If 32bit then probably something like this for ram
or for 64 bit
As for a video card your best bets are probably something like this
CPU should be good i believe but not sure bout mobo and since you already bought the psu and case and are on a budget we will just leave those out of it. This is all my opinion correct me if i'm wrong please :p
m
l
August 17, 2009 12:46:11 PM
after buying the ram you are going to have about $95
and the best card you can get for that money is a ATI 4850 or an nVidia 9800gt
The ati is a little better , but some games favour nvidia and the difference is less
m
l
August 17, 2009 2:56:32 PM
how do I figure 32 bit or 64 bit where do I look TO FIND THIS?
m
l
August 17, 2009 3:40:02 PM
It is determined by your operating system. If you buy 64 bit vista then you are running 64 bit and can make use of more than 4 gb of ram, if you are running 32 bit vista you can only make use of about 3.2GB.
m
l
August 17, 2009 4:23:58 PM
64 bit is the answer then
m
l
