APPROXIMATE PURCHASE DATE: Within the next few weeks
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, Active on a usual day 7+ hours.
PARTS NOT REQUIRED: Not re-using anything, everything needs to be brand new.
PREFERRED WEBSITE(S) FOR PARTS: CompUsa.com / NewEgg.com
PARTS PREFERENCES: NewEgg Wishlist
(For the link to go through, you may need to remove the "http://www.&.com/#034;", and it'll go)
OVERCLOCKING: Maybe
SLI: Yes, but after computer is up & running properly.
MONITOR RESOLUTION: Maximum.
ADDITIONAL COMMENTS:
Basically starting new, CompUsa seems legit & honest, meanwhile keeping prices low.
I'll get speakers after the computer is up & running.
Switched power supply from Ultra, to Corsair.
Basically, I mainly need to make sure everything is compatible, and won't overheat.
OVERCLOCKING: Maybe
