Problem going from 2gb to 4gb ram xp
- 2Gb Gpu ram going to 4gb? - Forum
- wil going from 2gb of ram to 4gb of ram make a difference - Forum
- RAM Problems: 4GB showing as 2GB (ruined ram and faulty motherboard slot) - Forum
- 2GB GPU + 2GB RAM + 32 bit Win XP = Problem? - Forum
- I have 4Gb of ram my windows xp is showing only 2gb? - Forum
- I have 4Gb of ram my windows xp is showing only 2gb? Forum
- Will Upgrading From 2GB of RAM to 4GB of RAM Make XP Boot Faster? Forum
- 4GB RAM + 2GB 4870x2 + Windows XP 32 Bit Forum
- XP 4GB Ram but crashes when I goes over 2GB usage? Forum
- 4GB of Ram or go with 2GB? Forum
- Solvedincrease RAM from 2Gb to 4Gb Forum
- SolvedI want to buy a asus gtx 650 2gb My pc is an acer with 4gb ram 400w power intel core 2 duo 3.00 ghz. Will this be ok or is t Forum
- SolvedI have two new 4GB RAM sticks and an old 2GB stick. Can I use them together to give me 10 Gbs of RAM? Forum
- SolvedGtx 770 2gb of ram or 4gb of ram Forum
- Solvedhey i am going to buy a new 4gb single chip ddr2 ram can you suggest me a fast ram for gaming usage Forum
- Solved4GB ram installed 2GB usable Forum
- Solved2GB RAM. I want to add 4GB Forum
- SolvedI have 1 2gb and 1 4gb ram chip.. is this forcing single channel mode? Forum
- Solvedi have installed 6gb of ram one 4gb 1600mhz and another 2gb 1600mhz my pc shows total memory installed 6gb but only 3.88 usabl Forum
- SolvedBIOS says I have 4GB Ram, Computer uses and says I have 2GB of RAM Forum
- More resources
Read discussions in other Motherboards categories
