Phenom X4 9750 OC to 2.76Ghz
Gskillz x4Gb DDr2@1066
Asus Radeon 4870 1Gb
ASRock 780GXE/128
Antec Earthwatts 650W PSU
With the release of the new 5xxx series from Radeon, I have been giving thought to my current GPU. At the moment it more than suffices, as my resolution is only 1400X900, but it has still given me cause to at least consider my upgrade options. This is all the more difficult, however, because I am not sure if my current PSU will support another 4870 in Xfire. According to the Antec power calculator, with my current set up and an additional 5870, I will need 711W of power at 90% load. So my question is, can this PSU handle that much load? I know that PSU's can often exceed their advertised limit, sometimes by a lot; can this one do the same?
Note: I know that the PSU doesn't have the requisite number of PCI-e connectors, as it only comes with 2, but if it could meet my wattage requirements, I would simply buy some molex to PCI-e converters.
The psu calculator doesn't provide you with actual power consumption numbers, it provides a wattage reccomendation for a power supply that will safely run your components, with some overhead built into the figure.
Being under by 50 or 60 watts won't pose a problem with a decent quality psu, such as yours.
As far as psu's exceeding their rating, it's nice to know that one can but it's not something you would want to do on a full time basis.
