Tom's Hardware > Forum > Homebuilt Systems > New System Build > Building a new system, lookign for tips and advice.
Forum Homebuilt Systems : New System Build - Building a new system, lookign for tips and advice.
I am building a new system and it has been a while. I am mainly using it for gaming and school work. All I have to work with is the monitor, keyboard and mouse. These are the parts I am hoping work together, let me know if you see any glaring problems.
Antec P183 Black Aluminum / Steel / Plastic ATX Mid Tower Computer Case - Retail
Case
ASUS M4A78T-E AM3 AMD 790GX HDMI ATX AMD Motherboard - Retail
Motherboard
EVGA 896-P3-1257-AR GeForce GTX 260 Core 216 Superclocked Edition 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
Videocard
CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply - Retail
Power Supply
AMD Phenom II X3 720 2.8GHz 3 x 512KB L2 Cache 6MB L3 Cache Socket AM3 95W Triple-Core Black Processor - Retail
CPU
CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model TR3X6G1600C9 - Retail
Memory
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
Hard Drive
LG Black 22X (CAV) DVD+R 8X DVD+RW 16X DVD+R DL 22X (CAV) DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD±R DVD Burner with LightScribe LightScribe Support - OEM
DVD Drive
There are all the parts. I was looking for some additional cooling for my processor, but wasn't sure what to buy since I could not find any that matched the processor I am planning on purchasing. Also, I know this is a probably a dumb question, but how can I tell if the dvd burner I am purchasing supports dual layer? Thanks again.
Sponsored Links
Triple channel RAM is for i7's, get this instead
OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop
http://www.newegg.com/Product/Prod [...] 6820227320
Also, this is of plenty power for that system:
Antec EA650 650W Continuous Power ATX12V Ver.2.2 / EPS12V version 2.91 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC
http://www.newegg.com/Product/Prod [...] 6817371015
A like these cases better:
Antec Two Hundred Black ATX Mid Tower
http://www.newegg.com/Product/Prod [...] 6811129070
Antec Three Hundred Black Steel ATX Mid Tower
http://www.newegg.com/Product/Prod [...] 6811129042
Yes that ODD supports DL.
Here's a nice cooler if you're overclocking, otherwise you shouldn't need one:
XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing
http://www.newegg.com/Product/Prod [...] k%20knight
------------------------------ How To Ask For Build Advice
Homebuilt PC Buying Guide
Reply to jbakerlent
A few issues, dont get a crossfire board and an nvidia card, if you are going to go nvidia get a 770 chipset on the board. Get a dual channel kit of DDR3 ram, its cheaper and will work better with any non i7 processor. Drop down to a 750TX or a 650TX. The 650TX will let you CF 2 4870s and the 750TX will handle 2 4890s easily. Also consider a larger case with better airflow, putting a big heatsink on the processor doesnt do a thing if there is no fresh air blowing across it.
Reply to hunter315
Also this HDD is faster but smaller:
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal
http://www.newegg.com/Product/Prod [...] f3%20500gb
Reply to jbakerlent
There are a few components that could use some attention. The motherboard you picked supports crossfire (ATI GPU's), not SLI. An ATI 4870 1GB will offer nearly identical performance as the GTX 260 and leave the option open of adding another GPU in crossfire later.
850W is overkill even for crossfire 4870's. You could go down to the 750TX and still have plenty of power.
The RAM you picked is a triple channel kit designed for the Intel i7 chips. Your system will work best with a dual channel kit.
Patriot Viper 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model PVS34G1600LLK - Retail $84.99
The "DL" in the product description indicates that the DVD burner is capable of burning dual layer DVD disks. The DVD burner you picked is capable of burning dual layer media.
Edit: Wow - I really need to work on my typing speed. You guys had a whole conversation while I was typing my reply. :)
Message edited by shortstuff_mt on 08-18-2009 at 12:30:16 AM
Reply to shortstuff_mt
- 0 +
Alright, I adjusted the order as needed. Take a look at it now and let me know anything glaring. Thanks again.
Case
ASUS M4A78T-E AM3 AMD790GX HDMI ATX AMD Motherboard - Retail
Motherboard
CPU
DVD Drive
And the changes...
SAPPHIRE 100259-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
Videocard
OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model OCZ3RPR16004GK - Retail
Memory
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power ... - Retail
Power Supply
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
Hard Drive
Reply to rverlie
Looks good. Nice job!
Much better, that build leaves you lots of upgrade potential too.
Shortstuff it seems we all need to work on it, i cant believe we got in 4 posts in a little over a minute
Reply to hunter315
- 0 +
Here are my final tweaks. Please let me know if you see anything out of the ordinary or if you think it will not work together, or suggest any simple upgrades, such as the HD. Thanks again guys.
Motherboard
CPU
DVD Drive
Power Supply
SAMSUNG Spinpoint
Hard Drive
And some more changes...
Antec Twelve Hundred Black Steel ATX Full Tower Computer Case - Retail
Case
SAPPHIRE Vapor-X Radeon HD 4870 2GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
Videocard
mushkin 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model 996601 - Retail
Memory
Reply to rverlie
Before you purchase that 2GB version of the 4870, I would also consider the 4890 1GB. I am not too sure about the extra memory really being worth the price on the 4870 but for the same price you could get a 1GB 4890. I would feel much better if somebody else could confirm this though. Everything else looks great.
------------------------------ Fire Protection Engineering Major @ UMCP
i7 920~ EVGA x58~ XFX 5770
Reply to waynec121
- 0 +
Wayne, that was the other card I was torn between as well. If anyone could confirm the difference between these two, it would be greatly appreciated.
Reply to rverlie
- 0 +
Also, with the system I am building, what would be the most compatible OS? I was reading reviews on many of the parts I am buying and have heard some troubles with different OS and whatnot. If anyone knows more about this, it would be greatly appreciated. Thanks again.
Reply to rverlie
2GB of memory is not needed on a video card, if you see this review
http://www.tomshardware.com/review [...] ,2380.html
the 285 is a ton stronger than the 4870 and still gets no benefit from the extra GB of memory
For $5 less after promo code you can actually pick up an OC'ed 4890 with vapor-x cooling
http://www.newegg.com/Product/Prod [...] 6814102841
Reply to hunter315
- 0 +
Ok I've narrowed it down between these videocards.
XFX HD-489A-ZDFC Radeon HD 4890 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
HIS H489FT1GP Radeon HD 4890 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Turbo OC Edition - Retail
Message edited by rverlie on 08-18-2009 at 08:05:13 PM
Reply to rverlie
Same price as the other xfx card but with hawx and overclocked halfway to the HIS card
http://www.newegg.com/Product/Prod [...] 6814150360
Thats the one i would go with.
Reply to hunter315
I would get the XFX one because I believe they have a double lifetime warranty. So if you ever sold it to someone they would have a lifetime warranty as well.
Reply to waynec121
- 0 +
Thanks for all the help guys. Any suggestions on an OS?
Reply to rverlie
http://www.newegg.com/Product/Prod [...] 6832116677
Will let you use all your ram and upgrade to windows 7 for free in a couple months.
Reply to hunter315
There are 465 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
