So I've been researching water cooling for a few days now, and here is a possible system (I think):
Pumps: 2x Swiftech MCP350's inside the EK-DDC Dual TOP V.2
Reservoir: Attached to Pump (RES Combo); 140 mm tube with EK-Multioption Top and EK-Multioption Link
Radiators: 2x Airplex Revolutions with 3x 140 mm fans each (pull only, Cooler Master R4-24S 1000 RPM)
CPU Block: Koolance CPU-370
GPU Block: EK-FC6990 Acetal + Nickel
Flow plan: Pump->CPU->GPU->Rad #1->Rad #2->Res->Pump
I plan to put the pump and res inside the case but the radiators (obviously) outside.
This is system is for cooling an overclocked Phenom II 955 and an overclocked Radeon 6990 (with a possible second 6990 in a future year).
I have 2 questions:
1. What do you guys think about my plan so far? Solid?
2. What brand of tubing/fittings should I use to make my loop? I know I need something thick and flexible, but more than that I have no idea.
Thanks!
I have 2 questions:
Thanks!
