Solved
Using a SATA power splitter
Hi, so in an effort to reduce clutter and improve airflow inside my case, I thought I should switch to this: http://www.newegg.com/Product/Product.aspx?Item=N82E16812119010
I have a few questions about it though. Currently I have a power cable that splits into, about 5, 4-pin molex connectors for fans, and I'm using it to power 2 fans directly, a fan controller, and 3 fans via the fan controller. All 120mm LED fans. So if I add another molex connection to that existing cable to power: 1 optical drive and 1 HDD, would the performance/functionality of any of these parts suffer? (The 5 fans, fan controller, 1 optical drive, 1 HDD) The 2 fans are connected to one molex via pass-through setup, so are the other 3 fans connected to the fan controller, so I am currently using up 3 molex connections out of the 5 available.
Hope I didn't make that too convoluted and it's clear enough for people to understand and hopefully help out.
Thanks in advance.
2 answers Last reply Best Answer
More about using sata power splitter
  1. Best answer
    That should cause no problems at all.
  2. Best answer selected by bprimetimel.
Hard Drives Power Fan Controller Storage
